I recently imported an R32 Skyline GTR to the US and I am having some trouble with the HICAS (I assume). Since Skylines are still new to the US (only '89s and '90s are technically legal so far) I figured you guys might be a better source of information than most of the people local to me.
The short version is: is it worth trying to troubleshoot a HICAS issue, or should I just get an eliminator kit? Does the HICAS provide any actual benefit? I understand what its purpose is, but I see mixed results about whether or not it is a good thing to have.
A description of the HICAS issue I am having is below.
If I accelerate hard to highway speeds (80+kph) while also turning (ex. using a circle on-ramp/interchange), the steering wheel will move off-center. Meaning the top of the steering wheel will be at the 11 o'clock position rather than 12 o'clock like normal. The car still seems to drive straight when that happens, just the steering wheel is no longer straight. After roughly 5 minutes or 10km, the HICAS light will turn on, and the steering wheel will automatically center itself again so the top of the wheel is at the 12 o'clock position and it will stay that way until I turn the car off.
Also, any time I drive at highway speeds for 5 minutes or 10km the HICAS light comes on, regardless of whether or not the steering wheel goes off-center like in the situation described above.
Any advice would be greatly appreciated. Sorry if this has been asked before. I tried to search but didn't see any posts with a problem similar to mine.
https://www.sau.com.au/forums/topic/459559-r32-gtr-hicas-issue/
In that case, do you guys recommend a simple lockout bar similar to this http://topspeedauto.com/nissan-skyline-gts-t-gtr-r32-89-94-jdm-hicas-bypass-kit-hicas-eliminator/, or a full kit like this one http://www.driftworks.com/driftworks-total-hicas-eliminator-kit-for-nissan.html?
Also, thanks for the feedback. I appreciate it.
Personally I'd suggest the hicas eliminator kit as you replace a tie rod and a (most probably) worn out ball join with a toe arm and new bushes
A lock bar is much cheaper, you might get some funny faces trying to get the rear aligned with all the hicas gear in there though
Edited by Jordy32
Driving a RHD car in a LHD country already gets me plenty of funny looks anyway. :cool:
I figured the full eliminator kit would probably be the suggested option, and I was leaning that way myself.
Unplug the small plug from the HICAS computer (in the boot, the box mounted on the right side).
Full eliminator kit is the way to go IMO.
Do you have an aftermarket steering wheel?
Do not have an aftermarket steering wheel, however I just imported the car from Japan 1 month ago so its history is mostly unknown to me and the exporter has not been good about providing information. I do have reason to believe it previously had a full roll cage installed so it stands to reason that other aftermarket modifications were installed at one time.
Edited by GoneGoose
The other things you (may) like to consider is all the pumping and pressure lines that serve the HICAS. You can just loop the thing and render it inoperable or you can do it properly and remove them. Also worth doing or atleast considering is replacing the standard power steering cooler with a small but decent cooler.
RE: steering wheels, sometimes the incorrect Boss kit throws the HICAS error (the computer can't figure out if you're turning or something).
But yeah, full eliminator kit is the way to go (it should include the loop for the power steering). Then rip out the HICAS stuff (weight saving!).
I echo this sentiment. Removing the hard lines all the way to the front is easy enough on a hoist. Looping at the rear is trivial if you buy a HICAS lockout or replacement kit that includes what you need. The PS cooler is just a loop of pipe and does very little. An auto trans cooler from an R34 is a bloody good size for the PS cooler.
Define issues? Do you mean just the physical problems of getting it out while the engine is in the bay? I wouldn't expect there to be. The solenoid can be removed with the engine in. The hydraulic lines to the pump and reservoir run under the engine and it is nice to be able to access everything more easily when the engine is out, but I'm sure that needn't be a problem if you're just removing the lines that run to the rear from the solenoid.
Mental note for anyone removing everything.....the R32 pump is a 2 stage (or more to the point a 2 circuit pump) with the rear circuit running the HICAS gear and the front running the PS. If you get rid of all the HICAS plumbing it is a prime opportunity to do something about getting rid of the 20+ year old PS pump in favour of a newer single stage pump. I did this by doing a Neo transplant, but that's cheating. I'm just pointing out that you can't just block off the HICAS lines as the pump is still pumping!
Thank you thats great! You can still use the standard power steering pump though right? If you were to replace it which would be the correct one?
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
