If you were to replace it which would be the correct one?
Probably any pump that will fit on an RB. Just need to get the pulley changed.
I did look into this a long time ago, but did not bother remembering what the right choice was, because I cheated with an engine swap. But the good news is that if you google, you will find.
Define issues? Do you mean just the physical problems of getting it out while the engine is in the bay? I wouldn't expect there to be. The solenoid can be removed with the engine in. The hydraulic lines to the pump and reservoir run under the engine and it is nice to be able to access everything more easily when the engine is out, but I'm sure that needn't be a problem if you're just removing the lines that run to the rear from the solenoid.
Mental note for anyone removing everything.....the R32 pump is a 2 stage (or more to the point a 2 circuit pump) with the rear circuit running the HICAS gear and the front running the PS. If you get rid of all the HICAS plumbing it is a prime opportunity to do something about getting rid of the 20+ year old PS pump in favour of a newer single stage pump. I did this by doing a Neo transplant, but that's cheating. I'm just pointing out that you can't just block off the HICAS lines as the pump is still pumping!
Pardon my ignorance but if it is a 2 rotor pump cant you just pull the vanes out of the rear rotor and job done?
  • 1 month later...
OP: Like you, I have a 1990 R32 GTR here in the US (Oregon). As part of my suspension refresh I have completely removed the Hicas system, including the rear components, the hardlines, and the front solenoids. It is pretty easy work, removes quite a bit of weight, and does reduce some of the odd handling caused by Hicas.
If you ever decide to do a suspension rebuilt, drop me a note.. I can give you all of the details on where to get the replacement parts here in the US.
Jeff
Jeff
Jeff, I appreciate the offer. If I ever decide to rebuild the suspension I will let you know so you can help me track down parts (beyond just throwing on coilovers, which is my next purchase). I am starting to think my HICAS issue is just the steering wheel position sensor, in which case I might just fix it rather than remove it. At least for now. One of these days I should probably get around to doing that.
On an unrelated note, I am also in Portland, OR. I haven't seen any other R32 GTRs on the road, but I had heard there were at least a couple around.
Edited by GoneGoose
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
