Hi guys can you guys help me out. How much am i looking at to turbo a stock N/A 2.5 neo 25gt4
1. Can you guys list me down all the things ill need and how much they will be and also how much installation and tuning will cost
2. Does a turbo kit come with everything Ill need ? or will i have to shop around for each individual part ?
3. Is the N/A 2.5 neo the same as the turbo version in relations to how much boost they can handle before internals need upgrading?
I have around 10k to play with can you guys give me a rough idea of what kind of power I will be looking at after everything is finished?
I will be looking at a bigger turbo then a stock neo version would like to have around 250-300rwk if the stock internals can handle it.
I know I'll be looking at around roughly $2k - 2.5k for a ecu and tuning already so will $7.5k - 8k be enough to get everything all good to go ?
Thanks in Advance.
Edited by Kei_ayanami
https://www.sau.com.au/forums/topic/459576-cost-to-turbo-na-25gt4-25-neo/
What you need.
1) a camera (phone will suffice)
2) a computer (phone will also suffice)
3) $50
4) post photos taken from phone or camera onto carsales via computer or phone
5) buy gtt/gtr by utilising phone or computer which has been previously acquired.
For $10k you should be able to buy an RB26 c/w gearbox and ecu (actually a half cut should get you the FMIC etc and if you are lucky the brakes as well.
Then you can update the brakes suspension and tyres.
Thanks in Advance.
I have a mate that bought one of these for a track toy, he put an RB26 in but reckons in hindsight he should've gone an RB25/30. You might be able to build a budget one for that around about that sort of money if you don't go for forged internals and all the fancy fruit.
Either that or get an RB25 out of a Stagea - wouldn't advise the 26 route though, too much stuffing about with wiring looms etc.
  • Like 1
Neo from stagea. Expect headaches with tons of random shit.
You are asking all the right questions, which means you will come to the conclusion that it is a bad choice.
Walk away - get gtt for rwd with a fancy aftermarket traction control for grip, or go gtr.
Path less travelled for a reason.
Source: travelled the path
  • Like 2
I am currently putting a Stagea Neo rb25det into an R34 gt four sedan...
Mainly because I really want a sedan, as well as 4wd.
The guys are right, there are a lot of things that will need to be changed, which you just get included with a GTT or GTR. If you really want to do it you need to swap motors - the stock gt4 Neo motor internals are not up to the task, you need a factory turbo motor.
The only scenario where it MAY be worth it, is as above, you wanted a 4 door 34 (for the shape?), cause R34 GTR is very pricey.
But the smarts is go sailing with a R33 GTR if you can, its just seriously the better option for reasons you don't know until you're like "oh shit why did I f**king do this holy f**k"
There's a lot of debate on these forums about how to approach a lot of different things
When EVERYONE says "sell the car and buy the proper platform" then yeah they're doing it for a reason
    • Sorry the pictures suck. So hard to get camera and light in there
    • One of the first jobs with the E39 is making sure the tailgate stays up. In BMW fashion they made a little cavity under the roof to hide the dampers rather than putting them down the side like everybody else.  As you can see I have these little cavities that house the dampers. When I cleared one out and vacuumed as much crap as I could out of it I noticed a fair bit of rust. The cavity is bone dry, even after all that rain we had only a few days ago so I'm assuming that whatever allowed the moisture in is fixed but I'd like to treat the rust in there.  I was thinking of just blasting it full of rust converter but I didn't know if this would be beneficial considering I can't actually get in there to prep anything.  Maybe there's a better product?  Thanks guys
    • Had a few skylines over the years anyway bought this a few years ago for skidz i think it’s been around these traps for a while anyway I plan to thrash and trash and I assume it’s going to send me broke good times
    • The stock boost solenoid is just a valve. Power it and it is open. Unpowered, it is closed. When it is closed, there is no boost bleed out through the solenoid back to the inlet. The wastegate sees all the boost pressure, thus you get the wastegate's spring pressure as your boost pressure. 5 psi. When it is open, it lets some boost escape. This causes the static (boost) pressure in the line to the wastegate to be lower than the pressure in the intercooler pipe. There is probably a small restrictor in the solenoid or one of its lines to limit the flow rate of the escaping air, which limits how far the static pressure can fall, which limits the extra boost. The boost has to climb above the original/wastegate setpoint until the wastegate sees 5 psi. You get 7 psi in the intercooler pipework. A manual boost controller is exactly the same setup, just without the ability to change it on-off. It's always set to whatever you set it to. There is a small leak from the boost controller. The more you screw the adjuster in, the more it leaks, the lower the pressure seen at the wastegate and the higher the boost will be. So, yes, your diagrams are correct.
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
