Ha ha the best thing you have ever written.
Seriously though, rbs are a prick to find water leaks. Check all the little hoses around the engine. I had a similar problem for ages and I thought the worsed and it ended up being the joiner near the clutch master cylinder, only saw it because I was under the car and noticed drip stains on the bell housing. Hopefully its just something like that. Usually if its head related the engine start to sound different.
Edited by XGTRX
A minute hairline crack in the flame ring, which only opens up under heat and boost is impossible to find without removing the head. You can try pressure testing, and carbon testing the coolant, but mine only ever pushed combustion pressure into the cooling system on heavy load. I drove it like that for a year before it let go in a big way. Depending where the leak is, internal or external, there must be coolant going somewhere it shouldn't.
Larger studs help, but they still don't have the clamp force of the newer 625+ or old L19 studs. Think of the studs as a spring pushing the head down onto the block.
I also use a little Hylomar spray on my MLS gaskets, just in case a small crack propagates it will hopefully stop it leaking. My engine builder does the same. Relying on the machinist to make a perfectly smooth block surface will likely end in tears I believe.
  • Like 1
Thanks fellas, I will write down all of your suggestions and pass it along.
If they do not find it on Monday I will have to think seriously about having the head checked out properly :ermm:
Here is the Video of the leak that was fixed
Keep in mind I had never seen this leak and had been looking for 3 months while I waited to have the repairs done, not a drop or wet spot.
Looks like we have got some good news on the coolant loss.
Enclosed are pics of the tool we made to constantly pressurise the cooling system at approx 20psi all day Saturday with no coolant loss.
This morning we put the tool back onto it to continue pressurising the cooling system and within about 10-15min the enclosed video will show you the result.
Prior to testing on Saturday we noticed a small amount of residue around that area but couldn’t confirm a leak during testing.
I just do not understand why it took a full day of being pressurized to 20psi and nothing, then 15 minutes the next day you can have a shower under it, but I am a cynic and have no expertise in coolant problems, maybe one of you blokes can explain it?
Leak.MOV
piss that silicone hose off and get oem.
metal and water mate. has to be the right conditions to replicate
The hose was changed
Do not understand the metal and water line ?
Just get them to do a compression/ leakdown test while they have it. That will tell you if you have a head issue. :)
Metal expands and contracts which could make or hide leaks.
It's a red hose... Ain't oem
Please understand, I do not know what is wrong or if anyone is to blame. I cannot help how my mind works .
The car was loosing water the same day I picked it up from the build and it was only using a similar amount of water for the 3 months while I waited to have the repairs done.. After the leak was found and "fixed" it was only a month or so before it started to loose water again and it ended up exactly the same as before the leak was found. In my mind, I find it hard to believe that the problem was fixed by changing the hose.
I think that nothing was fixed and that there was a patch job done by using some type of stop leak product and over some time it has gone back to how it was. I might be 100% wrong but for something to be acting in a certain way for months, then the problem was found and fixed, to go back to exactly the same problem, seems unlikely to me.
But it would not be the first time I have been wrong :yes::3some::3some::3some::3some::3some::rolleyes:
No one would use an additive to fix that type of leak.
Replace the hose and check the clamp doesn't have a rough edge. (Piercing the hose).
Make certain not to over tighten the clamp
Check the end of the pipe hasn't been taken out of round.
Take it in on Monday. If its a coolant leak then they will note it on a pressure test and then you have to find it (PITA), do a comp test and they will see if its the head/ gasket, if it's neither then as suggested the head might be lifting. I know its a pain in the ass but shit happens. Our cars aren't factory anymore and little shitty things like this happen often. Relax till Monday.
Additive to fix what type of leak ?
The hoses were changed to a black type , car came back OK then after some time went back to EXACTLY the way it was. Understand there was NO VISABLE LEAK at any time, they had it on a pressure gauge at 20psi ALL DAY and nothing! Then the next day you could shower under it ?
All I have said it is the strangest thing I have seen if this was the original problem, cant find a leak, find the leak in the most visible situation after HOURS of being pressurized, change the hose, leak fix, short time later after the leak had stopped, it slowly went back to how it was ??
I am just stating the facts as they are and the only thing that made sense to me was an additive was used to mask a problem that was in the too hard basket to repair, this "​does not mean" it is what happened but from years with cars and seeing how stop leak products work, it seems the same outcome ????????????????????
Alrighty. I see what is going on here.
Pete, we have to stop talking about previously for a second. You keep going back and forth and I/we are loosing track.
So the car has a black hose - tick
You don't know where the leak is...
You are pressure testing on Monday...
You think they used chemiweld (additive) to fix the hose....
Have you squeezed the top radiator hose close to the clamp with the car idling?
Hi, been away for the weekend
Firstly , some of you blokes should read what was said before you post.
I said the hose was changed at least twice in this thread , most of you know the story and still don't get it.
The water lose started the day I picked it up from the 3.2 build, waited 3 months to get the car back into the shop to check out the water lose and a few things to be sorted from the build.
They pressurized the radiator ALL day on a Saturday and found nothing, then did it on Monday and "found the leak "THE VIDEO" were it was pissing out. They changed the hose and said it was fixed , took the car home and for a month or so it was OK, THEN started to loose water again.
Now it is back to how it was after the build .
NO SYMPTOMS
NO water leaking under the car
NO water in the oil
No oil in the water
No bubbles in the water
No sign of leaks from ANY hose that I can see
NO water vapor out of the exhaust
So here I am about 5 months after the build, the hose was changed because they said this was the water lose problem. A month or so after the hose was changed and the water had stopped disappearing , it started again, it is no EXACTLY the same as it was before the hose was changed and NO SIGN WHERE THE WATER IS GOING!
The car goes in tomorrow and if nothing can be found I will have to take it in for a serious assessment , I would hate to stuff the motor up as the car runs great and shit loads of fun
Thanks for the blokes that had something to contribute :)
The other , HGAS :special:
  • Like 1
Hey 75 Coupe, my basic knowledge about cars is fine.
My knowledge about modifying cars was nil up to 18 month ago and it seems the more you learn the less you know , so I guess you have learnt a lot
  • Like 1
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
