  On 21/09/2015 at 9:13 AM, Nismo 3.2ish said:
Could do, do not know. I will probably have the motor out by the look of things and will see what can be done at the same time ???
Who is doing the work?
Why the cam change?
Were they dialled in extensively last tune?
Why not just chuck some chemiweld in?
Why the cam change?
Jez will be doing the work.
Cams were dialled for a more even result, top and bottom
I believe Chemiweld had already been used, but that is only a guess
If I did change the CR . probably go 9:1
But I will not make any decision until it is pulled down and the problem found and go from there once I find out the initial problem :(
  On 21/09/2015 at 9:42 AM, breaker1845 said:
If you're happy with everything else then why not just resolve the head gasket issue?
Who said it was a head gasket, hope you are right, I tend to always think the worse and anything less is always a better outcome :)
Not going to say anything until the problem is found and fixed, I will go from there but while the car is in the shop might do a couple of tweaks.
Car goes in 12th of next month :rolleyes:
I will not bore you blokes until I have some results and poke the new Dyno Graph up
  • Like 1
  • 4 weeks later...
hmm I was just thinking about this thread the other day.
cracked block would be a bad outcome, but it doesn't really reflect on any shop involved in the build, its more just bad luck. You were pushing a mile of power through a standard wall block and it's not unheard of.
I am amazed sometimes on this thread.
At first the water lose was on a low boost run in tune and limited to 5000rpm, this was in March this year.
This water situation started from the first day of the build, it was not noticeable at first as I was checking the radiator, cold in the mornings and not the overflow, once the overflow emptied then it was noticeable from the radiator. I have always checked from the radiator so I knew exactly how much water was being used, I used a measuring cup.
The amount used on different driving situations was and is the same from day one as it was when we found the water in the oil.
Yet the oil still looked clean on the stick , not as you would expect ?
Edward lee now crd?
If I am not mistaken they said they tak no responsibility for any issues after Jez touched it. Therefor the only way you will have a chance at getting them to fork up for the new repairs is by taking them to court.
Or am I mistaken
I took them to NCAT, a tribunal were you can negotiate and come to a mutual agreement, I sat at home on the phone during this procedure. he was just a smart arse and told me to fark off, I didn't!
This situation is early days and the motor has to be checked , I am sure it can be worked out, until then it is just another bump in the road.
Some blokes should put themselves in the other persons shoes before posting, think about what you would do in the same situation , roll over like a dog , yeah sure ?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
