I have noticed an odd noise that I assume is the traction control unit.
Each time I start up and move off, within a few second of moving off a strange 'burp'-like noise occurs - the vibrations of which can be felt through the brake pedal in particular. This happens without fail every time I move after starting the car up. After that it's fine. I noticed the same noise but extended when the traction control was operating after going around a tight, steep and slippery up hill corner.
Any insight?
Thanks
Luke
https://www.sau.com.au/forums/topic/459612-v35-strange-traction-control-noise/
I should add that the noise will happen regardless of whether I am accelerating, braking, or rolling - it's just more obvious when my foot is on the brake. It's always the same time after moving off - usually about 30 seconds.
Cheers
Sure its not a sticking brake caliper or slider pins?
Some pads on light brake pressure while moving make make a bit of a groan sound as the vibrate on the rotors, could be they are not releasing easily and partially on and draging.
