Hey everyone
Recently I've been having troubles with my 33. I bought it last year, and at the time it was running 14psi, with a high-flowed stock turbo, and nistune-chipped ecu (not a great tune, runs rather rich). Had no problems when I bought it. Other mods the car came with were splitfire coilpacks, upgraded fuel pump, turbosmart bleed valve, FMIC.
A couple of months ago I added a Greddy type s bov (car was bought without bov), which I had a few issues with setting up, because I tee'd it to the same vacuum line as the boost gauge, and it leaked boost. I turned the boost down for a while until I got around to fixing it (this car is also my daily driver so it took a while), but now I've fixed that up and both now have their own source of vacuum. I then turned the boost back up to 14psi.
Lately, when at WOT I've been hitting boost cut when it spools close to 14psi in 3rd and 4th gear, and also there seems to be a massive flat spot which is very noticeable through 2nd gear, which wasn't there before and seems to be getting progressively worse.
I've already changed the spark plugs, as I thought maybe the rich-running engine might have fouled them and caused the engine to run excessively rich, although the old spark plugs were not fouled when I took them out and the new ones haven't made any difference.
Any ideas of what else could be causing this?
https://www.sau.com.au/forums/topic/459633-r33-gtst-huge-flat-spot-boost-cut/
Could be the nistune falling into the knock map if it's Z32 ECU and the knock sensor mod on the board hasn't been done properly.
The ecu is r33 gtst
Are you running an airflow meter?
Block off the bov and see if it fixes it. If it does then I think the tune needs a bit of tinkering.
It's running a stock rb25 airflow meter. I'll try blocking off the bov again
Are you sure it's a nistune OR just a re-flashed R33 ECU?
Because R33 Nistune Type-6 boards are still in prototype and I don't believe they have gone to market yet..
Anyhow, these days you can use a RB20DET ECU with the new feature pack that controls VCT woots
Maybe the spark is giving out above 4000rpm. I know you have spitfires but that doesn't rule it out. Maybe you are running overly rich, fuel pressure regulator busted etc?
What spark plugs are you replacing it with? I hope you are not one of those guys that uses iridiums and gaps them down to 0.01mm. 0.8mm is low enough and use coppers.
The boost cut you are hitting because the AFM is running out of reading range. Nothing you can do about that unless you change to a bigger AFM, so just keep it under that point.
Edited by sonicz
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
