Selling this on behalf of my brother as he doesn't know how to post on here.
Car was painted a year ago and sat in the garage for most of its life.(he works long hours and bought a house so doesn't have time for it). Sits in the garage collecting dust.
Will update KM's once I have a chat with him as the cluster was changed as the old one had a broken rpm/speedo gauge).
1993 R33 Skyline
13/11/15 Rego
$10,000 Negotiable
Mods:
PowerFC ECU with hand controller
Splitfire Coilpacks
750cc Injectors
Garrett GT3071R Ballbearing Turbo
Custom Split front/dump pipe
3" Fujitsubo Catback exhaust
Front Mount Intercooler
Cusco COMP-S Coilovers
DEFI Boost Gauge
DEFI Control Unit
Turbosmart Dual Stage Boost Controller
19" wheels with new tyres
Excedy HD Clutch
Slotted Front Rotors
HEL Braided Clutch Line
New Brake Master Cylinder
New Clutch Slave Cylinder
New Bendix brake pads
Mechanical 2way LSD
Kenwood MP3/CD Headunit
Rockford fosgate speakers at rear, Kenwood speakers at front
Resprayed in BMW A34-7 Arctic Metallic (still have some paint left over)
Power Steering
Electric Windows
Electric Mirrors
Momo Steering wheel with Boss Kit
Apexi Pod Filter
(will also come with the standard airbox which has a new K&N Filter)
Oil Catch Can
All parts are genuine (DEFI/Turbosmart/Apexi Filter/Momo wheel etc)
Bad points:
Dent on the rear passenger side underneath the rear pod (prior to painting, so been painted over but not repaired)
Missing GT badge from left guard (lost at the painters)
Missing driver side kick panel, the one that sits near the accelerator pedal (lost at the painters)
Located in Silverwater, NSW.
This is the only picture of it I have at the moment:
Will take some photos tomorrow.
Cheers
Edited by cabramatta
https://www.sau.com.au/forums/topic/459648-r33-skyline-sydney/
interested. what power is it making? who tuned it? thanks
Just an update on this; made 270kw @ 21psi tuned at a place in castle hill which he forgot the name of. Will try to find the dyno papers to confirm the tuner.
Advan Performance recenly had a look at it as it was acting weird on boost hence the reason for the custom dump pipe as the gate flap was hitting it at times. Gave everything the green light after that.
I also forgot to add that it's running a series 2 motor aswell as a Z32 AFM & Walbro 255 fuel pump (AFM not pictured as it died for some reason even though it's an orginal unit. currently sourcing another genuine z32 replacement. have both plugs wired to run either/or).
Cluster was changed at 170,000km's~ and has only done about 2,000 km's (yes, 2000) in the past 3 years so <175k.
Looking for a quick sale so fairly negotiable within reason.
Feel free to ask anything else I might have missed.
Cheers
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
