Selling this on behalf of my brother as he doesn't know how to post on here.
Car was painted a year ago and sat in the garage for most of its life.(he works long hours and bought a house so doesn't have time for it). Sits in the garage collecting dust.
Will update KM's once I have a chat with him as the cluster was changed as the old one had a broken rpm/speedo gauge).
1993 R33 Skyline
13/11/15 Rego
$10,000 Negotiable
Mods:
PowerFC ECU with hand controller
Splitfire Coilpacks
750cc Injectors
Garrett GT3071R Ballbearing Turbo
Custom Split front/dump pipe
3" Fujitsubo Catback exhaust
Front Mount Intercooler
Cusco COMP-S Coilovers
DEFI Boost Gauge
DEFI Control Unit
Turbosmart Dual Stage Boost Controller
19" wheels with new tyres
Excedy HD Clutch
Slotted Front Rotors
HEL Braided Clutch Line
New Brake Master Cylinder
New Clutch Slave Cylinder
New Bendix brake pads
Mechanical 2way LSD
Kenwood MP3/CD Headunit
Rockford fosgate speakers at rear, Kenwood speakers at front
Resprayed in BMW A34-7 Arctic Metallic (still have some paint left over)
Power Steering
Electric Windows
Electric Mirrors
Momo Steering wheel with Boss Kit
Apexi Pod Filter
(will also come with the standard airbox which has a new K&N Filter)
Oil Catch Can
All parts are genuine (DEFI/Turbosmart/Apexi Filter/Momo wheel etc)
Bad points:
Dent on the rear passenger side underneath the rear pod (prior to painting, so been painted over but not repaired)
Missing GT badge from left guard (lost at the painters)
Missing driver side kick panel, the one that sits near the accelerator pedal (lost at the painters)
Located in Silverwater, NSW.
This is the only picture of it I have at the moment:
Will take some photos tomorrow.
Cheers
Edited by cabramatta
https://www.sau.com.au/forums/topic/459648-r33-skyline-sydney/
interested. what power is it making? who tuned it? thanks
Just an update on this; made 270kw @ 21psi tuned at a place in castle hill which he forgot the name of. Will try to find the dyno papers to confirm the tuner.
Advan Performance recenly had a look at it as it was acting weird on boost hence the reason for the custom dump pipe as the gate flap was hitting it at times. Gave everything the green light after that.
I also forgot to add that it's running a series 2 motor aswell as a Z32 AFM & Walbro 255 fuel pump (AFM not pictured as it died for some reason even though it's an orginal unit. currently sourcing another genuine z32 replacement. have both plugs wired to run either/or).
Cluster was changed at 170,000km's~ and has only done about 2,000 km's (yes, 2000) in the past 3 years so <175k.
Looking for a quick sale so fairly negotiable within reason.
Feel free to ask anything else I might have missed.
Cheers
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
