Hey guys, so I've recently picked up my new R32 GTR. I'm going to be covering everything I do to it in my youtube channel. I have already made a video show casing the new car. The link can be found here:
I've attached a picture showing what the engine looks like. Apart from the solid lifters in the 26 is there any difference in the cylinder head from the rb25's?
https://www.sau.com.au/forums/topic/459699-project-r32-gtr/
12030765 887241471344652 2055622383 N
Getting straight to the business!!! First day of the tear down. I went for everything hot side. I worked in an orderly fashion. Removing the strut brace (hoon bar). Taking out the AFM plugs. Removed the Greddy twin intake to expose that compressor wheel ;)
12016680 888674871201312 728528145 N
I then moved on to taking out the oil catch can and the connected hoses. I then worked around the turbine housing removing the bolts then getting to the oil and water lines for the turbo.
11998284 888674881201311 1423155074 N
After that I then got to work on the exhaust mani. There wasn't a lot of room on the bottom nuts but persistence prevailed. With everything loosened and almost all nuts off we were looking the goods.
12016616 888674874534645 688299622 N
But then I ran into a slight problem... The compressor housing was too big and kept hitting the strut tower wall. All I needed was that extra couple mill to get the exhaust manifold of the end of the studs. So then there was no option but to take the turbo off.
12026434 888674887867977 1773455693 N
With the turbo out of the way the exhaust manifold was fair game. It was a bit of a jiggle taking it off as there's that external wastegate and screamer pipe still connected. But we got there eventually :)
12007025 888674891201310 1175901640 N
I was so pleased with myself after a couple hours effort. Nothing was really too much of a problem and having one turbo instead of two make it so easy to work on the turbo. Definitely staying with the single.
Next I'm going to be getting into the covers and aiming to get some timing set up!
Will post updates soon :D
Edited by reden
https://www.sau.com.au/forums/topic/459699-project-r32-gtr/#findComment-7605601
Hello, back again. I've been trying to smash out as much as I can after work hours to get the head off so I can start cleaning and start the laundry list of things I want/need to do. So I began this day removing the Koyorad radiator (Koyo FTW). Simply unbolting the two rad supports up top then disconnect your hoses and rip her out!
12029040 887681907967275 1125179721 N
11999948 887681917967274 129954957 N
Next I took out this front unit that sits on the exhaust side of the cam and at the front of the engine. I can't remember what its called but I marked its position and unbolted it. Something tells me cam angle sensor or factory adjustable cam. either or none it came out
12030847 887681941300605 1399425251 N
After that it was time to hit up the cam covers and have a look at the cam shafts and everything else that lay beneath. Bolts hold the covers in place. There was a couple earths but after a short time there they were.
From here the front cam gear cover was taken off with a couple bolts and that exposed the cam gears.
12029054 887681991300600 309604890 N
I had also disconnected both the alternator belt and power steering belt by loosening the brackets on each unit to provide enough slack in the belt to remove it.
12025422 887681931300606 187878050 N
12007331 887681937967272 1600062802 N
I ended the day by getting a rattle gun in on that crank bolt. Then get a pulley puller onto the harmonic balancer. I later figured out i could have done my timing at this stage as I was unaware that the mark for the harmonic balancer was in fact on the cover that sits underneath the cam gear cover. It has a little notch in it used to line up cylinder number 1 with the balancer when setting up timing. Needless to say the balancer had to come off anyway so here it is...
12026666 887681994633933 453169935 N
I can't remember how long this time. Keeping in mind I'm not a mechanic and I'm still learning things as I go. I do enjoy it A LOT and I hope you can enjoy it aswell. I'll post up the removal of cams and setting up the timing soon. If you want to actually watch me do it I have a Youtube channel:
Where you'll find videos of my R32 GTR a long with my previous build on an R33 GTST RB25. First build video is scheduled to be out on the 27th of september :)
I'll report back over the next couple of days with the cams and timing :D
11999880 887682151300584 915297846 N
Edited by reden
https://www.sau.com.au/forums/topic/459699-project-r32-gtr/#findComment-7606028
Who has ever called it a hoon bar before?
Rb26 head has no vct.
On a new report accurent affair did a cop said when you see a strut tower brace it means they have been drifting and labelled it a hoon bar.
What was wrong with the car? Sorry I may have missed it, I started watching the video but the shaking black and white hurt my brain.
Hahaha it kinda does hurt the eye balls. umm the cylinder head is fkd and it has a coolant leak. There's a few other bits and pieces that need attention.
https://www.sau.com.au/forums/topic/459699-project-r32-gtr/#findComment-7606356
  • 4 months later...
Bit of an update since my last post. Long story short my bores are scratched up real good so I'm building a 700HP+ R32. I have released a few videos since my last post. I've also bought some new parts too. So basically I set the timing up and put cylinder #1 at TDC (Top Dead Centre) and marked both cam gears and the balancer. I then removed the cam gears by undoing the idle tensioner to give some slack to the belt. After that off with the old gears, balancer and belt. I'm sure someone's written a more detailed post on the timing of an RB. My videos should explain it in a not so much mechanical minded way.
12030780 888605627874903 219673351 N
So I'll leave a link here for anyone that wants to watch it Project R32 GTR Episode 3 - " Timing":
I have a lot of things I want to do to this car now that I have to rebuild the motor. I'll report back soon with some info for episode 4 :)
Edited by reden
https://www.sau.com.au/forums/topic/459699-project-r32-gtr/#findComment-7684867
  • 1 month later...
  • 3 weeks later...
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
