Hi all,
I've been advised to put an engine damper on my RB26 (R32 GT-R). I'd like to know if any of you have had experiences with an engine damper and what it did for you and an estimate in costs would be great too as I have no idea about them.
Thanks in advance for any help. Much appreciated.
https://www.sau.com.au/forums/topic/45971-help-what-is-an-engine-damper/
Why was it suggested?
An engine damper is like a little shock absorber that goes between the engine and the shock tower to reduce the engine rocking when you get on and off the power.
Good from drifting so the engine doesn't out your balance off as much.
it was used to reduce the virbration of the engine and the movement due to cornering. don't think it is a nessary for RB. but after "downgrade" from 6 to 4 cylinder car, it shake like hell in high rev... i am going to get one very soon.
Thanks for the info guys.
rs73 yes that's it.
It's said that I will get better response from it and yes it will reduce stress on my engine mounts.
HMM. I am wondering whether I really need it or not now. It's not too expensive in any case I suppose. I might try it.
its not as nessessary on inline sixes due to the natural harmony of the crank they dont vibrate as much!!!!
Don't think we really need it for normal street and circuit driving.
However might be needed for hard drifting, not because of engine vibration, but to prevent engine rocking from side to side when throwing your car sideways around a series of tight corners... So if u drift hard, then might worth consider it, otherwise put the money into something else...
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
