1989 Nissan A31 Cefiro
Pussy magnet + sunroof model + Non HICAS straight outta the factory.
130xxx KM chassis
100xxx KM motor
Body
-OEM front lip
-Stage21 side skirts
-Stage21 rear bar
-Aftermarket weathershields
-Series 2 headlights
-Series 2 taillights
Suspension/Handling
-HSD TT series coilovers, 8kg F 6kg R
-Cusco upper control arms (rear)
-DSpeed toe arms (rear)
-R32 GT-R sway bar (rear)
-JustJap 5 stud front hubs with fresh NGK bearings
-R34 5 stud rear hubs
-BM44 BMC
-New clutch master and slave cylinders + GKTech braided line
-R33 GTST calipers, new pads all round
-Braided brake lines and braided ABS delete kit.
-Work Emotion CR Kai, white, 17x9.0JJ +17
-Federal 595SS 215/45/R17
-GKTech hub bore ring adapters
Powerplant/Drivetrain
-Series 1 RB25DET
-RB25DET gearbox, proper conversion with working speedo and proper crossmember
-Exedy HD 5 puk clutch (brand new)
-4.5kg flywheel
-Kinugawa TD06SL2-20g with 20psi spring (brand new)
-2.5" hot side pipework
-Aeroflow intercooler (brand new)
-3" cold side pipework
-Bosch Z32 AFM (brand new)
-RB26DETT intake with working individual throttle bodies
-Denso 740cc injectors wired in with GT-R drop resistor pack
-SARD fuel pressure regulator
-Aeroflow 255l/ph fuel pump (brand new)
-Apexi PowerFC w/ hand controller
-DRiFT 3" pod filter, 3" turbo intake pipework
-3" turbo back exhaust into Bee*R 110mm cannon
-Tomei Traxx 2way mechanical diff 4.36:1
-5 bolt driveshafts
Interior
-R33 GT-R seats (series 3)
-C33 Laurel dash, all switches, clock and air con ducting works
-OMP steering wheel on AutoTechnica boss kit
-Turbosmart boost gauge
Other:
-Hydrodipped cam covers (urban camo)
-Resprayed engine bay
-OEM Nissan Key
-Late model centre console
-Brand new OEM gear shift knob, re-trimmed handbrake and gear shift boots
-VivaGarage floormats
-GReddy magnetic sump plug + DRiFT magnetic oil filter
-DRiFT oil catch can
-New gaskets, exhaust stud bolts, etc
The bad:
-Rear guards need to be lipped/rolled.
-No alarm/immobiliser
-Kit is a bit rough around the edges
-Currently not tuned
(Will make ~400hp tuned)
-Rego overdue (can still be paid).
-It'll probably need new coilpacks prior to a tune.
-Needs a new fan shroud.
-Needs GT-R throttle cable.
In no rush to sell and will continue to fix the remaining problems with it and get it tuned if I still own it by then.
$13'500 as is
Price will go up if I get it all shmick and tuned.
More pics on request or check out its build thread in the members rides section.
https://www.sau.com.au/forums/topic/459714-1989-a31-cefiro-for-sale/
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
