I am looking at fitting a universal fuel pump, eg walbro 255 to my R33 and I had a couple of questions on the wiring of it.
1, This may be a bit stupid, but from pics etc it seems like the wires and terminals are directly submerged in the tank with the fuel. How does this not ignite or pose an explosion risk?
2, I read that its a good idea to hook up a relay to get the juice from the battery direct. Its been about 10 years since I last did one of there, does anyone have a tutorial/diagram/link to video etc that explains it and what to use (or can you tell me now)?
Thanks all
Do you see sparks coming out everywhere when you flick switches?
Wires are fine as long as the insulation between them is fine.
I believe there may be types of wire that are suitable to use in fuel but i have never looked into it so not sure what sort
Remember that for a fire to start it needs an ignition point. Electricity does not provide an ignition point unless it suddenly becomes able to create a circuit between a gap. Think of how ignitors (think bbq lighters) and even spark plugs work.
This probably isnt a very good explaination
This is what I am using today - From Cal in an old post from a few years back. Looks simple to follow and I've done most of it in under 30 minutes. I need to change the pump so I'm procrastinating about changing the pump and finishing the wiring.
  • Thanks 1
if you're using a Walbro 255, there's not real need to hook up a fancy relay.. just bypass the FPCM by earth the fuel pump wire from the top connector of the fuel tank cover.
at 100psi load (which you won't ever hit) it only draws a theoretic max of 14amps @ 13.5v.. this would mean you're running 50psi of boost through the motor to achieve nearly 100psi fuel pressure....
Let's use real world numbers, your base fuel pressure is 3 bar, i.e. 43.5psi.. and you put another 1.5bar ~22psi through your motor.. that means you're only loading up the fuel system to 65psi or so...
Soooooo... that means using a Walbro 255 you're only drawing about 10.5 amps at full noise...
food for thought :)
food for thought :)
I never knew about this! It would have been so much easier to do this. I got a Walbro 400 E85 pump so I thought it necessary to do this.
Is it still fine to do it either way?
you should hard wire the E85 pump, they drain loads of current!
I've gone full boofhead on mine and have run 12ga wire to the fuel lid and to a 40 amp relay with a 30 amp fuse
Hmm, What you did is pretty much what I did.
My thoughts were this though (tell me if I'm understanding it wrong) Walbro would have never run such thin wire to the pump itself if they thought it would be a massive problem or that it couldn't handle it. Hell, they have 16 gauge from the pump to the plug it comes with. I have read at full tilt on E85 the pump will draw 19A (not sure if thats correct though). I selected 25A automotive power wire, relay and a 30A fuse.
If you read the specs you can determine how much you will be running at full load roughly. In general those bigger pumps draw much more current and if you are hard wiring you should use some thicker wire and an in-line fuse for safety measures. I've seen cases with the 460 pump drawing large amounts of current and burning through the stock wiring/fuel tank hat almost causing a fire.
Realistically the pump will draw as much current as it needs/wants for the given scenario and if the wire can't handle the current going through it you'll find out about it. Having said that it can be rare for it to happen and if you aren't pushing a fuel pump that hard then you probably won't ever experience that potential scenario. Better to be safe than sorry.
Further to this, even the relay won't last long with a Walbro 460L, I have seen many drawing over 30 amps, blowing fuses and melting relays and tank lids. The issue isn't the pump, or the wiring. I suspect the relays don't get enough voltage to pull in the contacts hard, hence the current spikes as the voltage drops due to the bad relay contacts. Some last days, some months.
A solid state relay would fix it, but you lose 0.7V over the output switch. Probably best to run a solid state relay to power the coil of the 70 amp power relay, that way you can be sure the 70 amp relay is getting the full 13V it requires to energise properly, without affecting it's ecu controlled operation.
Jesus - I didn't think it was that bad.
Guess I may have to go this route.
Scotty, what are most people currently doing with their bigger pumps? The solid state relay or bypassing the ECU operation all together?
right.
And with soldering the pump wires together for in the tank, I assume you would need chemical proof heat shrink or similar. Anyone know where to get this?
I personally have use chemical proof heat shrinks, however when they loosen up with age your wires end up being exposed...
Better to use crimps, then slide the hard cover off.. heat up the metal, fill with solder and slide the cover back on.
DO NOT BYPASS THE ECU, you need the trigger from the ECU that goes into the OEM fuel pump relay... if you bypass the ECU and your motor stalls, the fuel pump will keep pumping... in the event of an emergency you don't want that especially when fuel leaks are involved and heat.
Thank you for the info Johnny,
I'll see how mine goes but I believe I'll go the solid state relay unless there is some other way I should do it.
If I'm understanding correctly it should look like this
The idea is that the voltage coming from the standard wiring is significantly less than the voltage needed to keep the SPST/SPDT relay closed under load and that a solid state being a relay because it doesnt use a magnetic coil to close the circuit and copes better with small voltage levels making it suitable to use as a relay to charge the SPST/SPDT relay.
Correct me if I'm wrong unless there is a better way to do this all
SSR%20and%20SPDTSPST%20Relay%20Wiring%20
I think you've got the wrong idea...
SSR takes the trigger from the same trigger wire that comes out of the ECU to the relay at the back of the car.... do not use the output of the OEM relay to trigger your SSR because of the OEM relay dies you're f'd.
    • Nah, if I need to fit people in a car I'll just use the Mrs car, the MX5 is perfect for what I need as a fun little sports car for fun on the street As for getting in and out of the MX5, I have no issues as I am a short arse who does lots of mobility training 🥷 If anything, I have been looking at Daihatsu Hi-Jets for a work hack, I helped one of my mates move some stuff with one recently that he picked up from Just Jap, it was a little ripper and plenty big enough for what we needed, it would also be super handy for me as I do alot of gardening, and plan on having some veggie patches and native gardens in the place I buy next year when I retire I did alot landscape gardening and growing veggies prior to my current job, and loved it, and that is a hobby that can keep me sane in my retirement, and as such, the little 300kg load capacity would be more than enough for what I need it to move around I have been looking at utes for just this purpose for a while now, and a near new 2024 Hi-Jet can be had for under $30k And I would rather look at a quirky little Hi-Jet than pretty much any other little ute, well, apart from a Brumby, I love the little Brumby, and weirdly have never owned one yet I was going to buy a heap of raffle tickets to try and win the Brumby that MCM built for Subaru Australia, but sadly I totally missed the raffle, I even filled in some form to be told when the raffle started so I could buy tickets, but to my dismay I was never contacted and found out I missed it when I was randomly googling Brumbys last year... #conspiracy  Maybe I should just buy a Brumby for a little "work hack".....LOL I use to be indecisive, but now I'm not sure
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
