Hey peeps,
Im new to the forum but this is a great place to get info. Has anyone experienced their door actuators going bad? First my two back doors went one at a time and now the front passenger door has gone also. Only the drivers door opens. Can these be fixed or is replacing them my only option? Thanks
https://www.sau.com.au/forums/topic/459733-2008-v36-door-actuators/
With elec window issues it's usually the brushes int he motor that wear and therefore they can sometimes be serviced/fixed to make proper contact for conductivity, but with the lock actuators my understanding is that they just need to be replaced. I had mine go on my previous V35 and after considering getting 2nd hand I figured if going to do it, may as well get new to avoid having the same issue occur again in an unknown period of time given you don't know how old or worn the 2nd hand unit may be from a wrecker.
Faulty actuators was (is) an ongoing problem with V35's - there is a thread on G35Driver that shows how to replace with an off-the-shelf actuator for around $20. I did this mod to my V35 when I first bought it, and the actuator worked fine the whole time I had the car. I have no idea how the V36 actuator works, or if this is a viable option, but I would be checking it out before shelling out hundreds of dollars for new OEM actuators.
The thread is at:
http://g35driver.com/forums/interior-exterior/347409-5-door-lock-actuator-fix-updated-thread.html
I have never heard before this post about V36's having door lock actuator problems...that too 3 of the 4 doors like you mentioned. i would be checking fuses or wiring before you go buying new actuators. I also got 2 v36s both coupe and sedan and havent seen any such thing in the last 3 years owning them. A good electrician is the way to go imo :)
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
