M11 standard i'm pretty sure (from ARP), no idea on the pitch though. I had to buy one for the VQ as they run the same M11 thread on the head bolts.
Make sure you get a bottoming tap.
To be more exact its actually M11 X 1.5 (pitch) for RB25's and RB30's.
RB26's are M12 X 1.5 pitch.
Reason i know is because im about to convert a RB30 block to RB26 head bolt sizes tomorrow for fun.
Make sure you get the bottoming out tap so yo can reach the end of the threaded hole if cleaning threads, the next one back is the plug tap and will be short 3-5 turns from the bottom, the starter tap will be 5-8 turns short.
Im waiting on 12mm CA625+ studs to arrive and a i have a set of 11mm studs but the box is sealed and i dont want to open it as im selling them.
A stock RB26 head bolt with washer fitted is 99.91mm long from under the washer head to the very end of the bolt including the threaded section that enters the block.
Remove the washer and from under the bolt head to the end of the threads its 102.72 mm.
Washer is 3.10mm thick exactly. (so im a few 0.00mm out somewhere)
Threaded section entering the block from the lengths above is around 27.5mm.
From there you will just need to add what you need to protrude out of the head to get the nut full on when working out stud lengths.
Do you have the length Pete? I want to compare to the VQ bolts I have here. (Not that I really want to go cutting L19's down, but I will if I have to. :P)
I was just down at Barrys and he gave me a set of RB26 ARP2000 stud kit to measure up as im still waiting for my studs to arrive.
Complete length of the whole stud is 124.37mm end to end.
Threaded section that enters the block is 23mm
74.27mm un-threaded shaft length.
Threaded section that nuts go on is 27.1mm.
So 23mm into block, 74.27mm shaft length, 27.1mm threaded for nuts and washer=124.37mm total length.
Hope that helps you. :)
The VQ bolt is 120mm from under the washer to the tip of the thread, so the length would be perfect, but it has an M11 x 1.25 pitch, so if the RB25/30 is 1.5mm pitch that won't work unfortunately.
Are you sure its 1.25 pitch into the block? It would provide real torque when tightening down.
Whats the final torque on them? A lot less than 100ft/lb?
ARP's studs for 25's and 26's are 1.5 pitch into the block but (i think) 1.25 on the heads nut face end. (Much finer)
Yep, I was measuring the stock VQ25det head bolts, so it's the thread into the block. I can't remember the nm figures, but 76nm stock and 96nm for the L19's is stuck in my head for some reason, unless it was actually ft/lb figures.
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
    • Nah not the throwout bearing, it's something internal. I already replaced the throwout bearing. Mechanic misdiagnosed my car and thought it was a spigot bearing, went to another bloke who said it was an input shaft bearing. (I replaced everything when I pulled out the gearbox but didn't open up the gearbox.   In this video at timestamp 6:05 : Mine has the same sound  min
    • It is definitely to space it out and away for clearance during compression, and possibly for spring clearance to upper arm. That latter would only be true for springs that are same-ish diameter to stockers, and so that probably doesn't apply to Teins or most other coilovers.
    • Yeah, a mechanic who knows these cars told me even if I get a brand new gearbox the noise will return but will be less noticeable. I've heard someone also they this noise came back after 3,000km on a new or reconditioned gearbox. It is pretty f**king annoying though just hearing groaning most of the time lol. I wonder if an aftermarket input shaft bearing would fix the problem or how they are built.
    • All RB gearbags, especially the big turbo box, have rollover noise. Mine certainly does. Always has. Sometimes is worse than others - no particular idea why, although it is probably temperature related. I have smurf jizz in mine and have had to have it in there from the first day the box went into teh car. It simply would not select gears with the engine on, on day one, with normal oil in there. And so, the blue stuff has probably ruined almost everything synchro related in the box. But it has taken 12 or 13 years to get to the point where I simply must replace the box. It has become increasingly baulky of late, which might be symptomatic of the way I've been driving it, as much as anything. I shall have to make some corrections when teh new box goes in. Input shaft bearing noise will decrease with clutch pedal pressed because the drive is removed. But yes, more often than not noises that work like that are associated with the throwout. It won't matter either way, new box will mean this one can be relegated to the parts pile.
