M11 standard i'm pretty sure (from ARP), no idea on the pitch though. I had to buy one for the VQ as they run the same M11 thread on the head bolts.
Make sure you get a bottoming tap.
To be more exact its actually M11 X 1.5 (pitch) for RB25's and RB30's.
RB26's are M12 X 1.5 pitch.
Reason i know is because im about to convert a RB30 block to RB26 head bolt sizes tomorrow for fun.
Make sure you get the bottoming out tap so yo can reach the end of the threaded hole if cleaning threads, the next one back is the plug tap and will be short 3-5 turns from the bottom, the starter tap will be 5-8 turns short.
Im waiting on 12mm CA625+ studs to arrive and a i have a set of 11mm studs but the box is sealed and i dont want to open it as im selling them.
A stock RB26 head bolt with washer fitted is 99.91mm long from under the washer head to the very end of the bolt including the threaded section that enters the block.
Remove the washer and from under the bolt head to the end of the threads its 102.72 mm.
Washer is 3.10mm thick exactly. (so im a few 0.00mm out somewhere)
Threaded section entering the block from the lengths above is around 27.5mm.
From there you will just need to add what you need to protrude out of the head to get the nut full on when working out stud lengths.
Do you have the length Pete? I want to compare to the VQ bolts I have here. (Not that I really want to go cutting L19's down, but I will if I have to. :P)
I was just down at Barrys and he gave me a set of RB26 ARP2000 stud kit to measure up as im still waiting for my studs to arrive.
Complete length of the whole stud is 124.37mm end to end.
Threaded section that enters the block is 23mm
74.27mm un-threaded shaft length.
Threaded section that nuts go on is 27.1mm.
So 23mm into block, 74.27mm shaft length, 27.1mm threaded for nuts and washer=124.37mm total length.
Hope that helps you. :)
The VQ bolt is 120mm from under the washer to the tip of the thread, so the length would be perfect, but it has an M11 x 1.25 pitch, so if the RB25/30 is 1.5mm pitch that won't work unfortunately.
Are you sure its 1.25 pitch into the block? It would provide real torque when tightening down.
Whats the final torque on them? A lot less than 100ft/lb?
ARP's studs for 25's and 26's are 1.5 pitch into the block but (i think) 1.25 on the heads nut face end. (Much finer)
Yep, I was measuring the stock VQ25det head bolts, so it's the thread into the block. I can't remember the nm figures, but 76nm stock and 96nm for the L19's is stuck in my head for some reason, unless it was actually ft/lb figures.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
