Hey guys,
I'll keep this short for you, but I appreciate any help.
~$10k ish
1996 Series 2 R33 GTS-T
123,xxxkms
3" APEXi cat-back
Front and rear struts
and a front mount, whatever that is..
Pic below; paint work is generally in really good condition. Interior is clean and generally unmarked. Centre consoles hasn't been molested or cut up for gauges.
I have also linked a video for the engine idling. I assume this click sound when the rpm drops and climbs is normal, but someone who knows what their talking about might be able to say otherwise.
My main issues are: he doesn't have any of the books, and he doesn't know if the guy he bought it off did the timing belt. Realistically, he's only driven it about 2,000k's but I'm more concerned with the history before that.
I had a good crawl over the car, no dents, scratches, or obvious rusting in the body (boot and undernearth)
Do you think it's a reasonable price or do I have room to barter for legitimate reasons? Cheers for any help
https://www.sau.com.au/forums/topic/459774-should-i-buy-my-mates-r33/
Yeah I definitely plan on taking it to a local place to have it looked over.
Originally for a laugh I offered ~$6k just to see what would happen and he wasn't too happy with it. My biggest problem is that he kinda got shafted himself and bought it for around ~$12k and thinks he can make that back.
Like I said, aesthetically it's in really good nick; but it looks like there are a few cars on car sales that have had some decent work done and are around that ~$9k mark.
A lot of friends have said the same thing. I'm just really struggling at showing him that it's not actually worth $10k. Like, no matter how many links I send to him of similar if not better cars for less doesn't seem to make him realise it's not worth what he's asking. It's really quite frustrating.
I considered just getting a GTR but I don't have the extra +$10k to just go out and buy one. Bang for buck, are the GTS-T and GTR really that different?
yes they are.
But you need to be able to afford two GTRs if you want one.
It's true, buying a gtr and having no money after is not a good thing. You'll need to maintain it regularly and have funds for unexpected problems that may occur. So owning one and having enough to buy another is a baseline people use.
There is a big difference between the two, if you get the chance to take a ride in both you'll understand why.
$10k is definitely steep for a gts-t in my opinion and it may be best to find a another one instead of his to save any drama.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
