They could be genuine aftermarket RACING WHEELS!
You may well be sitting on a goldmine.
The only way to confirm the metallurgy, and thus the racing provenance; is to take a small sample of the parent metal, by cutting them.
In half.
PS; My lawyer would also like to know when he can expect to take delivery of your generous gift;
He's generally in his Sydney offices on Mondays, Tuesdays and Thursdays; but not until after 2pm.
PPS; My car says hi. But in a manly way.
Racing wheels have a high magnesium content.
Dale's suggestion to cut a wheel is plainly idiotic.
But I do have idiot friends.
You shall turn a rim upside down > Pour acetic acid aka vinegar onto or into a spoke > You should see bubbles > The chemical reaction you witness, is the formation of Magnesium Acetate > 'Tis fun to watch
  • Like 1
here are all the markings inside of the rim, plus have a look at the picture i posted in the initial post of the topic which was on the outside of the rim
Edited by IM-32-FK
I washed the cowshit off one just for you.
Your centre cap seems larger than mine?
Written between each spoke:
NISSAN
05U20 SK24
FORGED
16X8JJ30
JIL (don't have suitable keyboard for these symbols)
Then in Japlish on the centre cap:
"We Produced with Spartan Air"
NISSAN
05U20 SK24
FORGED
16X8JJ30
thanks thats the stock gtr wheel i got the rare n1 spec gtr wheel
Spartan Air never really became very popular, because they'd didn't actually land at an airport, they'd just get Gerard Butler to kick you out the door shouting "THIS! IS! LONDOOOOOOOOOOOOOOOOOOOOOOON!!" Assuming you were actually going to London, that is. I mean, if you were going anywhere else it wouldn't make sense.
brb, off to drill holes in my wheels for that N1 effect.
Edited by Hertz Donut
Sorry mate, unless I'm mistaken I didn't even see 'Nissan' or a part number on the back of the spokes. That doesn't fill me with confidence when it comes to their genuinity.
there is a reason for that, there is no such things as a n1 wheel
  • Like 1
Cos they are rare.
this guy gets it
i mean if they were copies then they would of put the markings around the center cap to copy the gtr wheel
why would they make gtst wheels the size of gtr wheels when they can just make gtr wheels because they sought after more
plus it makes sense they are n1 because of the drill holes make they 1kg lighter over all 4 of the wheels. They made it lighter because the n1 spec gtr is more race inspired then the standard gtr. And the nismo edition gtr is full race version because it doesnt even have a radio....thats minus 2kg off the overall weight...among other things they didnt put in it to reduce the weight
also that guy saying that theres no nissan part number for the n1 wheel --- of course there's not, its limited edition rare otherwise everyone would buy the n1 edition so they only made a few hundred of them i suppose
Are you positively annoyed friend?
also to correct my former post, it doesnt say 'alta'...it says something else...also to the other guy who was saying something about the markings, here are a few more i found on the rim
Edited by IM-32-FK
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
