mani124 Posted September 18, 2015 Share Posted September 18, 2015 Hi All, I am hoping someone can help me with my Skyline GT250 2005. I had a flat battery failure and tried to jump start but failed because probably battery had died. I then connected another spare battery but mistakenly connected the wires incorrectly. Since then, it seems the electrical system is not working at all. Headlights, Immobiliser, Ignition nothing works. I called Racv and they replaced the battery thinking the battery was really flat but no luck. Can anyone please help me how I can fix it? Thanks Link to comment https://www.sau.com.au/forums/topic/459813-v35-gt250-electrical-system/ Share on other sites More sharing options...
scotty nm35 Posted September 18, 2015 Share Posted September 18, 2015 I would say you have blown an ecu or two. Perhaps the IPDM relay board? Where are you located? Link to comment https://www.sau.com.au/forums/topic/459813-v35-gt250-electrical-system/#findComment-7606133 Share on other sites More sharing options...
mani124 Posted September 18, 2015 Author Share Posted September 18, 2015 I would say you have blown an ecu or two. Perhaps the IPDM relay board? Where are you located? Hi Scotty nm35, I am in Point Cook Melbourne. Thanks Link to comment https://www.sau.com.au/forums/topic/459813-v35-gt250-electrical-system/#findComment-7606210 Share on other sites More sharing options...
theponyremark Posted February 16, 2016 Share Posted February 16, 2016 It could be the the fuses found in the IPDM relay box behind the battery, the 100A fuses found on the positive cable/terminal of the battery or your BCM being fried. Try checking IPDM fuses and the relays, then check the fuses on the positive cable/terminal. BCM is about $400 delivered via Amayama (plus $100 labour for Nissan Ferntree Gully to install and program the BCM to your keys). Link to comment https://www.sau.com.au/forums/topic/459813-v35-gt250-electrical-system/#findComment-7684169 Share on other sites More sharing options...
scotty nm35 Posted February 16, 2016 Share Posted February 16, 2016 The 2.5L doesn't have NATS does it? I thought only the 3.5L needed NATS key programming... Anyway, I suspect by now it's either fixed or burnt out down a dirt road. Link to comment https://www.sau.com.au/forums/topic/459813-v35-gt250-electrical-system/#findComment-7684232 Share on other sites More sharing options...
theponyremark Posted February 20, 2016 Share Posted February 20, 2016 The 2.5L doesn't have NATS does it? I thought only the 3.5L needed NATS key programming... Anyway, I suspect by now it's either fixed or burnt out down a dirt road. 2001 to 2002 do not require programming. Only 2003 and beyond require NATS key programming. Link to comment https://www.sau.com.au/forums/topic/459813-v35-gt250-electrical-system/#findComment-7686582 Share on other sites More sharing options...
