Hi all,
I've got myself a set of rays re30's (18x9.5 +15) and i'm going to be refurbing and getting them painted Rays bronze.
Has anyone put re30's onto a gtt before, or can find any pics? I'm kinda curious to what it'll look like. I have a black r34 gtt and have gone down the route of black on black, but have always wanted bronze on black combo.
I'm sure it'll look mad, but i just wanna see if there's any photos of it being done. I can only find re30's on bayside blue GTR's when i google it.
cheers!
https://www.sau.com.au/forums/topic/459824-34-gtt-with-re30s/
RE30 is the perfect look for dish and yet have a spoke design to accommodate large brakes.
Believe it or not that those very wheels were stolen off a subsequent owner. And they didn't even have a mark on them. So sad.
  • 3 weeks later...
That looks sweet! Just stumbled upon this, mind me asking what those front/rear lips are and where did you get them from? Much hassle involved in the fitment?
cheers :)
Front lip is from vivagarage (however they have discontinued it) and rear pods were from a private seller (but you can buy them for $180 on JSAI). Fitment was direct bolt on, very easy
They look awesome man well done
thank you! I've also got skirts getting painted atm to fix the level gap between the front and rear haha. Mounted them earlier last week - refer to attachment. Now to make myself a few more kiliwasps!
Just priced a set of these up, (Nengun can only do 7 and 8 inches apparently?) and they're more expensive than I thought for a single piece Rays wheel.
yeh, I've found they're pretty rare especially in the size i got. Hooked these up for a price i couldn't refuse :D
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
