hey guys.
just looking for any expressions of interest.
and/or your thoughts on what the below might be a reasonable sale price.
i have my very first car which has seen literal blood sweet and tears.
have had this for many many years and couldn't bring myself to get rid of her. but....... it is time..
grand plans of restoring her. but don't have time, space, coin or space.. not to mention i am lazy... lol.
1980 datsun 200b.
what is in it.
  • fj20 na
  • 5spd box
  • front end brake conversion. V8 commodore calipers and magna rotors.
  • S3 bluebird disc rear end.
  • surge tank
  • fuel pumps low and high pressure
  • microtech M/LTX 8 - direct fire ignition.
  • pulsar radiator
  • 2.1/4 exhaust that will definitely need replacing.
currently hasn't been started for years. needs a new fuel line to the surge tank as it perished and split.
was running fine when pulled off the road. had purchased a R33 and she was no longer needed.
kept it rego'd within the ACT 12mths rules. but let it slip. car has never been engineered with this engine. so would be good for a project. or to transplant out.
before it was taken off the road. it had a top end rebuild done.
had a look at it a few weeks back to try and get it to start. couldn't get a socket onto the crank to try and move it. however. was able to turn the crank by hand. so isn't seized.
will probably look into getting it to kick over in a few weeks.
but if people could let me know if that is even worth my while or anyone now days would be interested in something like this. that'd be great.
cheers guys.
How much you chasing? I may know someone whose interested.
honestly i'm not really sure atm..
am trying to gauge from some responses.
being the sentimental attachement... 1 BILLION DOLLARS!!!!!!!! ;)
realistically. not sure. :D
Edited by dazman
Honestly I'd say bugger all maybe $1000. You'll probably see a better return parting it out (and that's probably what any buyer would do anyway).
thanks for the advice on that mate..
i have no illusions about this getting restored. but i need to move the whole thing in one hit. rather than parting it out.
the joys of lack of space..
:starwars:
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
