Hi chaps,
It seems whenever I take my car to the local track (Barbagallo), I experience the following:
  • fuel surge when tank is approx <60% full
  • high fuel consumption - roughly 6 laps will consume 1/4 of the tank
Additionally, when at the tuners, they said that the injectors are maxed out; they're not completely sure what the reason is. Initially it was believed to be a lazy pump, however after swapping that out, it seems to still be the same.
My fuel setup (and other possibly pertinent information) is as follows
  • R34 GT-Four (not sure if they run a different style fuel tank, or smaller fuel hosing, given it used to be an N/A car from factory)
  • RB26DETT
  • Approx 515hp on a hub dyno, which is usually reading a bit higher than roller dynos
  • Running E85
  • Deatschwerks 1200cc injectors
  • Walbro 460lph intank fuel pump
  • Standard fuel rail and FPR
  • Unsure of fuel filter, I don't think it's anything fancy, but has been changed a couple of times since switching to E85
Since swapping fuel pumps, not completely sure if the surging is still present, as I kept the fuel topped up each time I went out; however the workshop said the previous pump was secured well, and was low down, so there was no reason for it to surge previously.
I am considering putting in a fuel surge tank, -10 micron filter, new fuel rail and an adjustable FPR to try and fix all the above items, however just wanted to see if someone has any ideas before I embark down this road.
The other strange thing is that I know another car which is exactly the same fuel pump and injectors as me, however is sitting at 100hp more with breathing room on the injectors, and another car which has same injectors (different fuel pump), but is over 700hp
Thanks!
You should have heaps of fuel for that power level. Fuel rail and FPR "should " be up to it. Have you tested the fuel pressure? Maybe you have struck a dud pump. Have you wired the pump for full battery voltage? Have you seen the afr chart? Is it possible that it is a problem with the tune?
Hey guys, thanks for that!
I don't have any fuel pressure gauges on it, that's something the tuner did and said they had maxed out
Pump is wired up for full voltage, the AFRs were previously a bit on the lean end up top, which has now been rectified so that they're "safe", but I don't have a copy of it sorry ...
The tuner is very good, I don't think there's any issue on that front
Sorry for the noob question, but I if I had a fuel pressure gauge on it, and for example the fuel filter is blocked, that would then be able to tell me that the filter is blocked and the injectors are over-working/hitting max duty-cycle, due to the reduced fuel flow (given by the pressure)?
My R34 has had issues with fuel filters before. Changed to an Earls and changed that when it became blocked, but I noticed this by the car running lean under power, which coincidentally was about the same amount of power you have :P
All it took for me was to run one tank of 98 and switching back to E85 to see my filter full of stuff. Pretty much want to change it any time I do an oil change now, I would lose my mind if I didn't have a wideband that will cut the engine if the event of a lean condition as I'm super paranoid about fuel filters now.
those are 1000cc with normal rail pressures, those DW are a 4 or 5 bar base 1200cc rating.
your power is around 390rwkw and is around right for getting close to max. (390-420)
It's interesting how DW and other brands feel the need to rate injectors at higher pressure to make them sound larger than they are.
My 1000's are actually 5000cc at 100 bar rail pressure. ;)
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
