Hey guys, just bought some ENKEI RPF1 18x9.5 +38 all around to find they don't fit on the front but fit perfect on the back.
The back of the wheel is scraping against the front brake calipers stopping the wheel from rotating.
I tried 8mm spacers, still wasn't enough. Tried 20mm bolt on spacers and that poked WAY too much it looked ridiculous. No idea what to do at this point. I really don't want to sell them as it will be such a hassle to get new ones etc.
any suggestions?
https://www.sau.com.au/forums/topic/459934-help-enkei-rpf1-on-r33-skyline/
But but but but.....I'm trying to work out how they can be rubbing the back of the spokes on the caliper faces. This is not a reasonable situation.
Fact 1. RPF1s (17x8 +35 or 38 or whatever it is) fit on my R32 against R33 calipers (not that it should matter much, but R33 calipers will obviously sit radially a little further away from the axis than R32 ones would).
Fact 2. I've never sen other RPF1s not fit a Skyline under similar circumstances.
Fact 3. RPF1s should all have about the same thickness of material in the hub section. This is the material thickness that determines whether the wheel will clear the caliper face.
Observation 1. The wheel in the OP's photo appears to have a LOT thinner hub section than any other RPF1 I have ever seen. I would guess that some retard has machined a f**ktonne of material off the hub section.
If all the above is true, run away. Do not sell them (because that would be wrong). Do not try to use them with spacers, because that would be stupid if they have been molested.
Yeah put them up last night sold them this morning for $1800 which is roughly what i paid.. Time to look for a new set of the same wheels.. :(
So im guessing i need a +15 to +25 offset and that should fit perfect?
What forum section should i post a WTB thread in for these?
They would have gone on with a bit of work. $1700 -$1800 is the going rate new here in aus. I bought mine in from the us for under $1500 delivered, but the dollar was better. And mine are the widest RPF1's available.
I have 18x9.5+15 WITH a 25mm spacer up front, and 18x10.5 +15 rear, now has a 35mm rear spacer. with 25mm front and 35mm rear fenders. But ran it as a street car like that for a couple of years.
They won't fit on a gtst.
When you put a 20mm spacer on that would have made the wheels a +18. Now imagine another 3mm out from there.
You need 8" upfront.
they WILL fit on a GTST. You just need to mod the guards. I ran rolled flared OEM Metal for a while, and then when to origin +25mm FRP Fenders. Your wheel alignment also plays a major part in it. Also tyre sizing.
10744884_10203677194142648_1617544223_n.
Fact 3 is incorrect. The spokes taper differently as they get wider. Many brands of wheels do this. Commonly referred to as a "FACE" Offset is a part of the equation, but not all of it. My 9.5's and 10.5's taper differently.
Had to sell them had no other options, sorry only saw all these comments now. Dont have any other pics but yeah was a very strange situation.
Like i said specs were 18x9.5 +38 all around
I Previously ran Enkei ABC Exclusive wheels in 18x9.5 +35 and 18x10.5 +35.
I actually still have them. They run a more concave face, therefore allowing more calliper clearance.
There are plenty of people running wider and lower offset wheels than what you're suggesting.
You really need to consider all of the following, not just a width and offset and thats it.
- Width
- Offset
- Wheel Face tyre - some offer more or less room on the face for calliper clearance. Enkeis are generally pretty good with clearance,
- Tyre Size
- Alignment
- Ride Height
- Spring Rates
TBH, you could have just gone with a 10mm longer wheel stud and a 10mm slip on, or a 15mm bolt on, or a 20 and more camber, for every degree of negative camber you run, the too of the wheel moves in 5mm (Generally)
Edited by R31 drift pig
  • Like 2
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
