Hey guys, just bought some ENKEI RPF1 18x9.5 +38 all around to find they don't fit on the front but fit perfect on the back.
The back of the wheel is scraping against the front brake calipers stopping the wheel from rotating.
I tried 8mm spacers, still wasn't enough. Tried 20mm bolt on spacers and that poked WAY too much it looked ridiculous. No idea what to do at this point. I really don't want to sell them as it will be such a hassle to get new ones etc.
any suggestions?
https://www.sau.com.au/forums/topic/459934-help-enkei-rpf1-on-r33-skyline/
But but but but.....I'm trying to work out how they can be rubbing the back of the spokes on the caliper faces. This is not a reasonable situation.
Fact 1. RPF1s (17x8 +35 or 38 or whatever it is) fit on my R32 against R33 calipers (not that it should matter much, but R33 calipers will obviously sit radially a little further away from the axis than R32 ones would).
Fact 2. I've never sen other RPF1s not fit a Skyline under similar circumstances.
Fact 3. RPF1s should all have about the same thickness of material in the hub section. This is the material thickness that determines whether the wheel will clear the caliper face.
Observation 1. The wheel in the OP's photo appears to have a LOT thinner hub section than any other RPF1 I have ever seen. I would guess that some retard has machined a f**ktonne of material off the hub section.
If all the above is true, run away. Do not sell them (because that would be wrong). Do not try to use them with spacers, because that would be stupid if they have been molested.
Yeah put them up last night sold them this morning for $1800 which is roughly what i paid.. Time to look for a new set of the same wheels.. :(
So im guessing i need a +15 to +25 offset and that should fit perfect?
What forum section should i post a WTB thread in for these?
They would have gone on with a bit of work. $1700 -$1800 is the going rate new here in aus. I bought mine in from the us for under $1500 delivered, but the dollar was better. And mine are the widest RPF1's available.
I have 18x9.5+15 WITH a 25mm spacer up front, and 18x10.5 +15 rear, now has a 35mm rear spacer. with 25mm front and 35mm rear fenders. But ran it as a street car like that for a couple of years.
They won't fit on a gtst.
When you put a 20mm spacer on that would have made the wheels a +18. Now imagine another 3mm out from there.
You need 8" upfront.
they WILL fit on a GTST. You just need to mod the guards. I ran rolled flared OEM Metal for a while, and then when to origin +25mm FRP Fenders. Your wheel alignment also plays a major part in it. Also tyre sizing.
10744884_10203677194142648_1617544223_n.
Fact 3 is incorrect. The spokes taper differently as they get wider. Many brands of wheels do this. Commonly referred to as a "FACE" Offset is a part of the equation, but not all of it. My 9.5's and 10.5's taper differently.
Had to sell them had no other options, sorry only saw all these comments now. Dont have any other pics but yeah was a very strange situation.
Like i said specs were 18x9.5 +38 all around
I Previously ran Enkei ABC Exclusive wheels in 18x9.5 +35 and 18x10.5 +35.
I actually still have them. They run a more concave face, therefore allowing more calliper clearance.
There are plenty of people running wider and lower offset wheels than what you're suggesting.
You really need to consider all of the following, not just a width and offset and thats it.
- Width
- Offset
- Wheel Face tyre - some offer more or less room on the face for calliper clearance. Enkeis are generally pretty good with clearance,
- Tyre Size
- Alignment
- Ride Height
- Spring Rates
TBH, you could have just gone with a 10mm longer wheel stud and a 10mm slip on, or a 15mm bolt on, or a 20 and more camber, for every degree of negative camber you run, the too of the wheel moves in 5mm (Generally)
Edited by R31 drift pig
  • Like 2
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
