Hey guys,
I'm wrecking a series 2 r33 gtst manual. The car has had a heavy impact front hit so the bonnet and fenders are quite damaged. Interior is stock and in excellent condition. The car has 154xxx KMs on the clock. As the car was hit front on, the radiator and aircon and a couple of pipes are munched up. Other than a munched up radiatior and a couple of bent/broken pipes, motor should be ok.
I will upload photos soon and will continue to update this thread as parts are sold and I will also post a list of mods the car has (not many).
Parts are located in Perth but I am happy to ship.
Best to text me on zero42059319four
Cheers
Amir
https://www.sau.com.au/forums/topic/459935-wrecking-r33-gtst-series-ii/
  • Replies 81
Interior is all out (including all rubber window and door sills) except carpet and steering wheel. All parts are in excellent shape.
Boot lid and its hinges also off the car.
HKS Electronic Boost controller (with wiring, hoses and solenoid) - $185
Seats (full set, no rips tears etc) - $330
ABS unit - $165
Skyline floor mats - $105
Boot and series 2 spoiler (silver) - $250
Dash (with vents, no cracks or bubbles) - $200
Stock airbox and intake (K$N filter, a couple of small holes) - $140
AFM - $ 60
Windscreen washer bottle - $110
Steering rack - $270
Brake booster - $80
Brake master cylinder - $100
Also available, diff, brakes, hubs, various interior trim, hood lining, and heaps more. I am wrecking the whole car so many more parts available.
All prices negotiable
Edited by AMR33
Cross member sold.
Many other parts available including interior, brakes, Carpet (not cut, no holes or rips), seats (very good condition), tail lights, rear bumper, diff and heaps more
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
