Hi guys,
I recently had my MY11 WRX clutch replaced as the previous throw out bearing had given way. When I drove the car away I noticed a rattle in 2nd gear in the 1500-2000rpm range. The mechanic suspected a heat agile but he removed them and the rattle was still there. I'm thinking his knocked/dropped something and that has loosened something internally.
If someone could help with some answers as to what could be vibrating that would be appreciated and would help me with my case against the mechanics..
Cheers,
Gino
https://www.sau.com.au/forums/topic/459956-my11-wrx-rattle/
I was more getting at a subaru forum being more helpful (as more likely to come accross someone who has had the same issue)
But it was a bit of a blunt comment in hindsight
Haha, I think my reply was a little blunt too. :)
  • Like 1
https://www.sau.com.au/forums/topic/459956-my11-wrx-rattle/#findComment-7609490
All good, Your point is a fair one. And I have absoloutly no problem with those that have been around and are done with the Skyline scene posting here and contributing to the forum etc. Just OP has joined the forum to specifically ask a question about a WRX. It's got me more confused then anything
https://www.sau.com.au/forums/topic/459956-my11-wrx-rattle/#findComment-7609498
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
