For sale is my 1989 R32 GTR, I purchased the car a little over 4 months ago in thinking it would replace my current daily driver. The car has 107k something kms on it according to odometer but since it was going to be my daily driver I wanted to make sure it was reliable so I did a complete servicing for the car and replaced the usual parts I that I thought to be failure points through wear and tear. The car is completely standard except for the things listed below and all the work was done less than 3000kms ago. The car ​IS ELIGIBLE for club permit but it is currently on full registration.
Reason for sale : Intending to buy an Evo as a daily driver instead. I'm used to lighter cars for the weekend driving I like doing and the GTR just feels a little too heavy for my liking.
Price : I'm asking 21k for the car with no RWC and has Rego until 15/05/2016.
12004927_10153070525230423_4870794020632
11217186_10153070999525423_5034287002104
11998877_10153087502320423_2741384686946
What has been done by me: (all work done by chasers motorworks with receipts)
-Timing belt
-All drive belts
-New Water pump
-New koyo plastic top radiator
-All oil flushed and serviced
-New brake pads and rotors all round
-resouldered and resealed Airflow meters
-New OEM fuel pump
-Dyno run to make sure AFR is healthy
-Full open door respray by DT Panels in Grigio Telesto (Lamborghini grey)
-Dunlop Super Xyphos 3 piece wheels
Whats been done by previous owner before i bought the car:
-R33 engine and turbos
-R33 gear box
-Exedy heavy duty clutch
-All bushings replaced with urethane couterparts
-Ohlins suspension
If you have any questions about the car, Feel free to contact me at 0411820696
https://www.sau.com.au/forums/topic/459967-wts-1989-r32-gtr-vic/
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
