Business: AM Performance
Owner: Andrew
Number: 0401 865 373
Address: Unit 4/ 31-49 Greenwith Road, Golden Grove, Adelaide, South Australia 5125
Email: [email protected]
Website: http://www.amperformance.com.au/
Facebook: https://www.facebook.com/AM-Performance-135203453221377/
Specialist in: Custom exhausts, fabrication and Titanium raw material, tube, flanges, brackets etc. and custom fabrication of titanium exhaust systems
Edited by GFXman
https://www.sau.com.au/forums/topic/459980-deleted/#findComment-7609862
  • 3 weeks later...
Business: Synergy Motorsports
Owner:
Number: 82697769
Address: 51 MAIN NORTH ROAD
MEDINDIE GARDENS
SA 5081
Website: sinergymortsport.com.au
Facebook:
Specialist in: imports and services. Mods. And can do the full English fix and maps for our V36
https://www.sau.com.au/forums/topic/459980-deleted/#findComment-7621305
  • 5 months later...
  • 1 month later...
Has anyone used these guys before?
http://www.autoperfection.com.au/security/
I just got my 350GT and want an alarm system installed. It says they install Dynamco systems which have an option which upgrades existing factory systems. I've sent them an email, but if anyone else has any input or suggestions, that would be great!
https://www.sau.com.au/forums/topic/459980-deleted/#findComment-7725479
    • Thanks for advice chaps   so you would change idler and tensioner bolt as well ? I guess because you thinking they have stretched once ?   i have done some research and on nissan belt and seem to hold 700hp but thinking HKS to be on safe side   i think I put nissan there last time   also thinking of changing cam cover to glass style:)
    • Nissan/Pitwork is fine stuff. HKS is just marketing wank. I personally wouldn't do the idler if it is already new. If it looks and feels fine, it is fine. But as D says - it's cheap to add it to the job. The water pump ditto. Even more so. If it show no signs of problems, then it is nearly new - leave it.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
