I'm back to bother ya'll again. hehe. I'll get right to it, Please follow my story below:
I had this tapping/knocking noise on rb26 that came on 1 minute after i cold start it but it would go away after 20 minutes initially..
I took a stethoscope and poked around the whole top of the engine. From the cam covers, all i could hear was the injector ticking but when i put it on the cam angle sensor or the timing cover ( i have a clear plastic one). It was clearly audible as in it hurt my ears listening to that knock.
So I took out the CAS and everything and
The shaft on the CAS was greasy with no rubbing marks but the O ring was still good. I installed another good used CAS but the knock was still there.
Then I found out that the previous retarded owner had not put the gasket and spacer grommets on the clear timing cover when he installed it.
eBut he included the original cover when I bought the car so I checked it out and as I suspected, the old timing cover still had the gasket and the washers stuck on it. So I went ahead and installed it. And this happened..
There is a knock and ofcourse the whining noise.. I have no idea what it is. How do I diagnose what it is? Would it be safe to diagnose with the engine running like that?
https://www.sau.com.au/forums/topic/459990-rb26-whineknock/
Maybe the timing belt was put on too tight or too loose or on an angle and something is slapping against something that shouldn't there, or the tensioner is going bad,
I would seriously get the timing belt redone including bearings because if its snaps you will almost certainly break the engine. I hope its not the gates racing blue belt either as Ive heard they are POS.
https://www.sau.com.au/forums/topic/459990-rb26-whineknock/#findComment-7610499
Took the timing belt cover off. There were no rubbing marks on the timing cover.
Intake cam gear was grinding with the vack cover and the exhaust cam gear slightly grinding as well.
Timing belt a little tight. I'm not sure how tight its supposed to be. Found some rubbing marks on the inside teeth of the timing belt for 1 inch.
Is the ok for the timing belt to move back and forth? Any comments on the grinding? What can be told about those rubbing mark on the teeth?
http://s27.postimg.org/k7t1lauwz/20150928_154209.jpg
Video showing the timing belt play and cam gear grinding :
https://www.youtube.com/watch?v=GclZnyZXrFI
Edited by gotenek
https://www.sau.com.au/forums/topic/459990-rb26-whineknock/#findComment-7610630
That is a serious sound.........I am not there [so its kinda hard to tell where its really coming from], but I would be super worried and looking hard at the motor and not just the timing belt. You have major issues IMO.
But wind your motor over and check the timing marks all line up for a start.
One last thing, where did the drop of coolant come from........its on the wrong side for the water pump and hoses??
https://www.sau.com.au/forums/topic/459990-rb26-whineknock/#findComment-7610700
I am very worried as well which is why I try to research as much as possible before I do any further diagnosis or find out how to do this diagnosis.
I pulled the coolant line in front of the timing cover and it dripped a bit. Nothing to worry about lol.
https://www.sau.com.au/forums/topic/459990-rb26-whineknock/#findComment-7610703
Man just get a timing belt kit, belt water pump and bearings. Preferably get a genuine kit. Re do the whole thing. You don't want to risk the timing belt or tensioner snapping on you.
Nothing wrong with Gates timing belts, providing they are genuine. Usually incorrect installation leads to problems for any belt.
I have no personal experiences with them, but I have heard WAY to many bad stories about the V racing gates belts to ever use one. Stories such as things being perfect at first, then the car developing timing issues or the belt rubbing off after only 20-30,000ks after installation, whereas the genuine nissan belt would go at least 100,000k with no problems. Not just from one source but the same story repeated over and over again.
Edited by sonicz
https://www.sau.com.au/forums/topic/459990-rb26-whineknock/#findComment-7610730
I've been using gates belts for years on road and my race car with no issues.
but anyway, that noise is horrible but almost certainly something rotating at the front. If I understood right you are saying the cam gear (intake in particular) is rubbing on the backing plate, that definitely should not happen. Also as Ben said that belt is dangerously loose and must be fixed ASAP, it is at major risk of skipping one or more teeth which can ultimately stuff your valves.
https://www.sau.com.au/forums/topic/459990-rb26-whineknock/#findComment-7611017
Thanks guys. After many confirmations, online and IRL, i know for certain that the timing belt is super loose. I will be pulling the engine in a week to change the oil pump, timing belt, tensioner, idler, spring, intake and exhaust gaskets, aac gasket.
Will definitely update on how it goes as everything is unfolded in the engine.
Thanks again everyone!
https://www.sau.com.au/forums/topic/459990-rb26-whineknock/#findComment-7611437
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
