Hi Guys,
Up for sale is an F-con V Pro Gold with patch loom for BNR34. This came with my car when I bought it but I since had it tuned locally to suit my EFR 8374, 1000cc injectors and E85.
As you can see in the photos it comes with everything needed to plug it directly into a R34 GTR whilst still retaining the stock ecu for basic stuff. It also comes with the map sensor to suit and the loom to connect that map sensor to the ECU.
Was working fine when pulled and was only pulled out as I upgraded to an Elite 2500.
These are a great ECU for relatively little money and being one of the earlier ones there are tuners all over Australia who can tune them.
Price is $800 ONO.
Pickup preferred over post but will post at buyers expense. Items are located in Rouse Hill, NSW, 2155 and my number is 0403858714.
Thanks,
Brett
HKS ECUs can be tuned by Tune House as well as a a couple of others.
I have a disk manual for this too, if required - gratis.
  • Like 1
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
    • Bit of a similar question, apprently with epoxy primer you can just sand the panel to 240 grit then apply it and put body filler on top. So does that basically mean you almost never have to go to bare metal for simple dents?
