Hi,
Just wondering if these endlinks are worth their money as opposed to the supplied somewhat crude looking endlinks?
(It's for an adjustable rear end swaybar on an R33 GTST)
http://www.whiteline.com.au/product_detail4.php?part_number=KLC109&sq=12993
Cheers
Supplied endlinks
Edited by Torques
Are they worth the money? Possibly not, depending on how much value you place on money more than any other consideration. If you asked the question "do they do anything?" then the obvious answer is, yes. They are like any other solid joint. They don't allow any slip before transmitting the forces to the suspension component. The reaction of the bar to cornering loads is sharper, quicker. Better. Worth the money? Probably. I haven't been able to justify buying them to myself yet.
The HD ball link is a lot nicer and more durable than the horrible loop style arrangement.
If you purchase a Whiteline front and rear bar kit for the R and S chassis cars now; they actually include the HD ball links.
They also deal much better with angular misalignment than the loop style ones; as they often just pop the bush out of the eyelet.
I can supply these for a pretty decent price if you're interested; shoot me a PM.
urrrgh...those whiteline ones are like a lot of their stuff, overpriced for what they are.
Hardrace are good gear
http://www.hard-race.com.au/index.php?route=product/product&path=25_28_687&product_id=180
fair enough...but the Hardrace ones are half the price of the whiteline ones, what's your definition of expensive?
Yes, you're right .. the Whitlines are very pricey and don''t look that convincing.
I also found these:
http://www.ebay.co.uk/itm/2-X-NISSAN-SUNNY-N14-1990-1994-REAR-BACK-ANTI-ROLL-BAR-DROP-LINKS-/130864103104?fits=Car+Make%3ANissan&hash=item1e781bbec0
http://www.ebay.co.uk/itm/NISSAN-PATROL-1991-1997-FRONT-PAIR-STABILISER-ANTI-ROLL-BAR-DROP-LINK-x-2-/291282784503?fits=Car+Make%3ANissan&hash=item43d1ce90f7
But am unsure what dimensions (length) I need
Edited by Torques
I think you're mistaking the pictures of the basic Whiteline ones that come with the bars and the uprated Whiteline ones that cost some coin.
Hmmm .. aren't these the ones?
http://www.whiteline.com.au/images/products/KLC109.JPG
They look a bit skimpy at the connecting link (the straight part) but maybe I'm wrong.
About AUD 150 in the UK and that is after a 10% discount :(
Edited by Torques
Funny you should mention that, i have heard vague rumours of them breaking. Not enough to make a "thing" of, but, just that i had read that a few times before so could be something to it.
I mean for the price it should be top notch quality really ... it's a lot of money, almost what I paid for the sway bar itself
I think they only look skinny in the middle because the ends are so bulky. I mean, face it, they don't look like they are made of smaller material in the middle than any normal end link. That's got to be ~8mm threaded rod at the connection there.
The connecting threads are M10.
The only "Failures" I've seen are the result of people not tightening the locking nuts on the threaded section or on the aluminium "Turnbuckle" section; which allows the tread to fret, and eventually fail.
OK, thanks ..
Would anyone know how much 'preload' there is on these bars?
I mean how much do I have to adjust the length of the connecting links?
(with the car on the ground)
Yes, sorry I didn't made my question clear enough.
I was concerned about the length adjustment of the end-links.
There's no such thing as "pre-load". With the car on a level surface there are no forces acting on an ARB.
I guess the best (most centralised) adjustment will depend on your ride height. Realistically the setting you're looking for will be to ensure it doesn't bind/hit anything at your max bump or droop likely to be experienced.
The other consideration is that you might tweak the length of the links depending on which hole you have the bar set to. Probably only talking ~1 thread adjustment there though!
I bought a set of the "expensive" Whiteline ones off Dale because the ones supplied with the bar sat at a bit of an awkward angle. They have withstood a hammering on the track with the weight of my 1800kg Stagea on slicks being thrown into corners so I don't think they are too fragile...
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
