joel
Freebaggin,
What specs A/Rs is your turbo, and what  motor?
It's all above.
Joel,
No split dump.
I'm much more confident it will make 300+ with more boost and cams (I'm just not going to try for a while as it has stock pistons and I drive it every day).
Tim has has very little to do with my setup for some time now and is probably pretty unfamiliar with what turbo he actually got me. I only run a bit over 17psi and get 280rwkW, plenty more to come. Look at Whatsisname's power with the boost increase from 14 to 23?? psi, 250 to 300 (OK, 299.1 or something), give or take some other bits and pieces, but not a huge amount.
YEah sorry Clint, but it along the same lines as your thread tittle. But please tell us to piss off whenever you want :D
Freebaggin,
What is the .63 housing off? VL???
What engine is your turbo on?
Not 100% sure what exh housing. 2.5L, full boost by 3400rpm, power drop off on dyno above 7000, but on the road still worth revving to 7300rpm, so 4000rpm odd rev range is good for me.
I have an RB25DET
I am running a 56 Trim T3/T04E (Flows 65 lbs/min). It's got a .60 compressor housing, .63 AR exhaust housing, and a stage IV 76 Trim exhaust wheel. It's got a standerd Bushing center housing. Runing Stock exhaust manifold with an adaptor box for the 38 MM external wastegate. I don't see boost till 3K (5 PSI) and full boost comes on at 4200 in 3rd gear. It comes on really strong all the power at once! I am only running 10 PSI and still running the stock RB25 SMIC intercooler.
Once My PFC and Q45 MAF comes I am going to fit my FMIC on and run more boost till the injectors are maxed out.
I guess a Ball bearing Turbo will make boost 500+ RPM's sooner. Must be nice.
How about an adjustable cam gear? How much would that help?
Clint, if your having troublechoosing a turbo, go see Shaun down at BoostWorx. Im sure he could recommend something, based on what you want from your setup. He always listens to what you have to say. Great guy :D
If you want his number or address send me a pm. :)
I agree Darren. Clint, give Shaun a call and see what he thinks.
Had a quick peek under your bonnet on Sunday Darren, that motor is a total 'sleeper', the engine bay looks stock as :)
I had a peep under Clints bonnet over the weekend - will be a absolute weapon
I reckon Freebaggin is on the right track with the turbo selection, if anyone can come up with a turbo to suit your applicaztion on paper, he can, as he put ALOT of time into selecting his and graphing almost every available option to suit RB25
Can't wait to see it in action, cheers for letting me use the hiost mate, thanks heaps
Chris
0.82 a/r rear on the rb25 might bring boost on 2 early.
I got 0.87 a/r rear and 0.70 a/r comp garrett on internally stock rb25 and it hits 1 bar by 4000rpm and can still torch the tyres in 2nd and 3rd when running 1.4 bar when boost comes on and sometime when running 1 bar even. With cams, headwork etc i wouldnt go 0.82 coz you will just have a tyre frying car which can never put the power down to the ground on normal street tyres.
    • People think it's a waste of space, ugly, etc, generally associate "emissions control equipment" with "bad". These OBD1 vacuum-only systems I'm not a huge fan because I think they don't go far enough. They're wasting some of the fuel captured because they start purging as soon as the engine pulls vacuum. Later OBD1/OBD2 they put an electric purge valve on them to vent only when closed loop is active so the ECU will trim some fuel out. Even later OBD2 with zero evaporative loss the tank is 100% sealed from atmosphere until you run the engine or press the refuel door release. The tank has to take much higher vacuum/pressure spec but you never deal with saturating the charcoal canister and losing some fuel that way. The fuel also lasts as long as it would in a 100% airtight container which is nice when you're dealing with modern E10 pump gas.
    • If your luck is anything like mine, what happens is in the process of pulling hoses to get access to the one leak you create many more leaks because every o-ring was on the verge of failing and the strain of pulling it apart caused it to fail. Sometimes life is simple, sometimes you pay twice trying to save once. For the R33 you can still get most AC components from Nissan, I use nissan epc data or amayama to look up the part numbers and then search for the cheapest/most practical way of sourcing from there.
    • The dirty secret is there is nothing recyclable about the plastic bag or old plastic bottles either. Our local trash collection explicitly calls it out as hazmat in both cases. Oil-soaked rags + paper towels too. Oil-soaked cardboard is also not recyclable. The most common case of oil-soaked paper like that is pizza boxes, which are explicitly compost-only from the oil. To my knowledge hazmat oil contaminated plastic the only solution is either landfill or "thermal recycling". Most plastics in my experience there is slow permeation of the oil it's holding into the container so it's very challenging to get it 100% clean.
    • Yes, and since RAA insurance essentially being swallowed up by the same monster that is NRMA insurance and all those other clowns, they are no bloody good now either. We dropped RAA insurance for the house a little while back because they lost the plot.
    • I can tell you now, good luck if you're with NRMA (NSW equiv of vis RACV and QLD RACQ). Because NRMA are freaking horrendous to deal with for claims, even with a normal road car. Not to mention even more BS when they're in the wrong and didn't cancel a policy etc when they were meant to and make you jump through hoops for things.
