joel
Freebaggin,
What specs A/Rs is your turbo, and what  motor?
It's all above.
Joel,
No split dump.
I'm much more confident it will make 300+ with more boost and cams (I'm just not going to try for a while as it has stock pistons and I drive it every day).
Tim has has very little to do with my setup for some time now and is probably pretty unfamiliar with what turbo he actually got me. I only run a bit over 17psi and get 280rwkW, plenty more to come. Look at Whatsisname's power with the boost increase from 14 to 23?? psi, 250 to 300 (OK, 299.1 or something), give or take some other bits and pieces, but not a huge amount.
YEah sorry Clint, but it along the same lines as your thread tittle. But please tell us to piss off whenever you want :D
Freebaggin,
What is the .63 housing off? VL???
What engine is your turbo on?
Not 100% sure what exh housing. 2.5L, full boost by 3400rpm, power drop off on dyno above 7000, but on the road still worth revving to 7300rpm, so 4000rpm odd rev range is good for me.
I have an RB25DET
I am running a 56 Trim T3/T04E (Flows 65 lbs/min). It's got a .60 compressor housing, .63 AR exhaust housing, and a stage IV 76 Trim exhaust wheel. It's got a standerd Bushing center housing. Runing Stock exhaust manifold with an adaptor box for the 38 MM external wastegate. I don't see boost till 3K (5 PSI) and full boost comes on at 4200 in 3rd gear. It comes on really strong all the power at once! I am only running 10 PSI and still running the stock RB25 SMIC intercooler.
Once My PFC and Q45 MAF comes I am going to fit my FMIC on and run more boost till the injectors are maxed out.
I guess a Ball bearing Turbo will make boost 500+ RPM's sooner. Must be nice.
How about an adjustable cam gear? How much would that help?
Clint, if your having troublechoosing a turbo, go see Shaun down at BoostWorx. Im sure he could recommend something, based on what you want from your setup. He always listens to what you have to say. Great guy :D
If you want his number or address send me a pm. :)
I agree Darren. Clint, give Shaun a call and see what he thinks.
Had a quick peek under your bonnet on Sunday Darren, that motor is a total 'sleeper', the engine bay looks stock as :)
I had a peep under Clints bonnet over the weekend - will be a absolute weapon
I reckon Freebaggin is on the right track with the turbo selection, if anyone can come up with a turbo to suit your applicaztion on paper, he can, as he put ALOT of time into selecting his and graphing almost every available option to suit RB25
Can't wait to see it in action, cheers for letting me use the hiost mate, thanks heaps
Chris
0.82 a/r rear on the rb25 might bring boost on 2 early.
I got 0.87 a/r rear and 0.70 a/r comp garrett on internally stock rb25 and it hits 1 bar by 4000rpm and can still torch the tyres in 2nd and 3rd when running 1.4 bar when boost comes on and sometime when running 1 bar even. With cams, headwork etc i wouldnt go 0.82 coz you will just have a tyre frying car which can never put the power down to the ground on normal street tyres.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
