Super Pro Bushes, bought them for my R34 GTT, but not going to install them anymore.
SPF1202K - (RRP $74.06)
Front Strut Bar To Chassis Mount Kit
SPF3153K - (RRP $102.60)
Front Control Arm Upper-Inner Kit
SPF1811K - (RRP $181.06)
Front Control Arm Upper-Outer Eccentric Kit
SPF1483k - (RRP $155.00)
Front Control Arm Lower-Inner Bushing
SPF2681K - (RRP $41.39)
Steering Rack & Pinion Mount Bushing Kit
SPF1750K - (RRP $74.46)
Rear Control Arm Lower-Inner Bushing
SPF1638K - (RRP $81.82)
Rear Control Arm Upper-Inner ⁄ Outer Kit
RRP is based on GSL Rallysport, and it comes to a total of $710.39.
Willing to let them go for $650. Check http:⁄⁄www.superpro.com.au⁄ for more information, to make sure it fits your car.
Pick up SE Melbourne, can be posted at buyer's expense.
https://www.sau.com.au/forums/topic/460028-r34-gtt-super-pro-bushes/
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
