Hi all,
just got consult3 today and give a try on my M35.
actually I have HICAS error code on dash that i want to scan. i found Consult3 will not scan HICAS module and i can't add HICAS module to scan list
my consult3 version is v09.21.01.00.00
here are some screenshot on consult3:
1. choose M35 for scan, there is no manufacture date info
2. consult3 will add the modules for scan automatically. there is HICAS module but it will not add to scan list
3. consult3 could recognize 6 modules from my M35 for scan
4. here is the scan result and there is no hicas error
anyone could tell me how to scan hicas error code with consult3? :woot:
Mr Nissan?
Can't say I have ever tried, I hate wobbly wheels with a passion. Ditch it and put a non hicas subframe in is my advice.
nope, just bought fake consult3 from aliexpress and want to scan for hicas error code.... don't want to pay much money to nissan for error code reading... :sweat:
currently i am using aftermarket ECU and i am not sure it is from hicas car or non hicas car. maybe i could switch back stock ECU then scan again?
Edited by YangLIU
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
