Hello
I have a R32 GTST with a RB20 DET.
I am planning to build the engine but before I do I want to get some info on the RB25.
What are its strengths and weaknesses?
How is it when put into a R32 GTST?
What are the pros and cons of putting that engine in a R32 GTST?
There have been literally millions of words written about this. Do a basic search first.
Ive done a search, I want to get up to date experiences. I spend about 8 hours plus research this on many sites.
Not just that, but we've all been saying it to Yoshii since he emerged, and those experiences are definitely up to date. I only did my Neo32 transplant a couple of years ago.
f**king awesome.
Edited by GTSBoy
f**king awesome.
I read some things about the RB25 and I thought I read several places that something about the oil pump or something to do with the oil that the RB25 has trouble with more compared to the RB20. I've actually heard a few people where I live mention the 25 is not all of that and its keep what I have or go RB26 or GTR(This is from tuning shops also). So I want to hear from people who have the engine in their car and who has done the change so I can ask about how it drives, speed, etc. Reading old posts from years ago(which I have) is not going to completely help because I am not going to try to PM someone or reply to a 2-10 year old posts.
I dont know how to express my laughter at that post. What an outrageous response.
Implying that there is not enough documentation about a) how the motor performs and b) WELL KNOWN oil issues
Its almost the single most popular conversion ever
HAHAHAHAHAHHAHAHAHAHAHHAHAHAHAHAH
Maybe you don't understand, I am wanting to speak to someone here and now so I can ask that person hear and now. Maybe I have specific questions about the engine or their experiences with the engine, what problems they may have had, what things that helped them, etc.
I reckon I'll be buried with mine..................gunna be crowded though, already have two motorbikes to throw in as well. Any vehicle that can be pushed as hard with a standard motor - such as the humble RB25 or 26 - to the point where you can get more than twice the power output for every day reliable street use for stuff all $$$ and TBH minimal mods deserves respect.
I honestly cannot see the point of your thread.........but its a free world until you shoot someone!!!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
