Maybe you don't understand, I am wanting to speak to someone here and now so I can ask that person hear and now. Maybe I have specific questions about the engine or their experiences with the engine, what problems they may have had, what things that helped them, etc.
Yoshi, I already told you my personal opinion on exactly how much better an R32 with a 25 in it (and specifically a Neo) a looooog time ago when you first started asking about how to turn your RB20 into the world's biggest nugget. I told you then, many others told you then, and I tell you now, and many others will tell you now, that Nissan should have put the 25 into the R32 right from the start, instead of persisting with the 20. A 32 with a 25 in it is the way they always should have been. Neos are just a whole lot better again (although the improvement from 25 to 25 Neo is much less noticeable than the improvement going from the 20 to the 25).
Edited by GTSBoy
  • Like 1
I read some things about the RB25 and I thought I read several places that something about the oil pump or something to do with the oil that the RB25 has trouble with more compared to the RB20. I've actually heard a few people where I live mention the 25 is not all of that and its keep what I have or go RB26 or GTR(This is from tuning shops also). So I want to hear from people who have the engine in their car and who has done the change so I can ask about how it drives, speed, etc. Reading old posts from years ago(which I have) is not going to completely help because I am not going to try to PM someone or reply to a 2-10 year old posts.
hrms...
no sure what problems... I track my car often enough, it has a completely stock motor and yet to see it explode.. and it makes a lazy 340kW at the rears.
How it drives? I drive it like I stole it, out of corners smashing the limiter.
  • Like 1
25's have more capacity and VCT, of course they are better than rb20's. The oil issues have solutions, other than that if you treat it right it will be fine
I never had issues with my old stock motor running 18psi and 260rwkw. The only reason i changed it with a fresh one is because i wanted to build an engine and thought i may as well make it strong
Seriously. If guys on a Skyline forum where I'd say around half the members have or have had an RB25 are telling you a 25 will be better then a 20, then really what more info do you need?
Its all here to be found if the time comes and if you already know about the oil issues then theres not much more to know as far as im concerned
if you do decide to do the swap though, then make sure you post up a 'how to' and how it worked out for you, so that the information is online somewhere if anyone else ever decides to do it in the future and wants to search for such information.
  • Like 3
Search.......whats that?????
RB20DETs are gay, I had one.. SR20DETs non-VCT makes more torque, hectic a SR20DET VCT makes even more torque.
I've owned a RB20DET so I can bag them out, they're shit.
  • Like 1
I quite liked my stocker RB20 in my old R32, was a good stock motor (ate and spat out a bolt, destroying the stocker turbine) and was good on petrol. But mine wasn't making 400hp.
But since you're going to take the engine out, put an LS1 in.
  • Like 1
Besides the cost of buying the engine, putting it in, and registration fee and higher car taxes of putting a RB25 in my car, I just feel its a pain to have to change the speedo cable, use different types of coil packs, have to have the weird wiring, etc.
If I put a 26 in the car it would be so much easier for certain things and parts able to use between the engines. But unless I get a good working 26 for cheap, I will buy a GTR instead of putting one in my car.
How about the crank collar issue with the 25 if pushing high hp? Is that something that I would not have to worry about unless going high high hp? Is the VCT the thing that really makes the big difference in torque between the 20 and 25?
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
