Hi everyone,
My rotors need replacing and I was wondering if anyone could tell me if these....
(http://www.ebay.com.au/itm/271713295431?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT)...
from US will fit? I contacted the supplier and they will not accept returns if incorrect fitment (box will have been opened and disks/rotors tested onto vehicle.
They say these are guaranteed fitment for US models only and cannot say if they will fit JDM.
Any help would be appreciated.
Details I have sourced (and sent to them) is:
If your V36 is a USDM 2009+ model equivalent, then DBA 4000T3 series will fit. They have the 42314S (front) and 42315S (rear).
These are listed for the "Infiniti G37 Sport Package (355mm front)" in DBA's international catalogue.
These are the identical discs listed for the 370Z with Brembo brakes.
They measure in at:
---------- Diameter - Height - Thickness
42314 - 354.6 - 49.5 - 32
42315 - 350 - 62 - 20
You know, there are a lot of places in Oz you can get these.
DBA is an Australian Company.
Your part numbers are correct if yours is a sport brake equipped model, I run those on my coupe with Project Mu Pads.
Great combination imo.
Edited by mycarhasposessedme
What he said. Even if it only exists in their US catalogue, you can still order them from any DBA supplier here. Don't let them tell you otherwise. I had this argument with my local supplier, who couldn't find the 4000 series discs part number for my Maxima in his Australian catalogue. He insisted it didn't exist.
I could've saved myself five minutes of arguing by showing him the email from the beginning rather than at the end but I enjoy a good argument and like to see what kind of people I'm dealing with. :P
Hi Colin. Just to confirm. I did some searching on the web and seems more of these rotors are listed for Z34 (or 370Z). So these are the same? 370Z with Brembo brakes are the same as my 370GT with big brake package?
Appreciate your time.
  • 1 month later...
Update: Bought full set of black drilled and slotted from US, complete with ceramic pads. $650 shipped to the door. Fitted by Gavin @ Autotech. They look great and perform well. Thanks for your help guys!!
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
