Good morning sir,
In order for this great community to assist you in this half arsed attempt at seeking information on something that you are not well rehearsed in then we will require a little bit more information on what you require.
  • Like 1
It's the big round thing under the steering wheel to the right...... You put the pointy thing that came with your car in it and turn and It makes the car manual for you to control.... Amazing stuff really. Technology these days just blows my Mind! BOOM[emoji378][emoji95]
Edited by Lakes101
  • Like 1
I'm thinking Lee has an error code he wants cleared?
Plugged in the consult II 1 error code "Manual mode switch" this will not clear at all
The manual shift worked fine before I pulled the engine and fully stripped and rebuilt it. Left the box in the car and only unplug from the engine, leaving all harness's wires plugs where/next to final place been.
Reason for not pulling box out with engine was space plus subframe was easy to clean off with the CV grease ect covered all over it.
Cheers Lee
Cheers man you learn something new every day.
Is it you 1st day to school too ?
  • Like 1
I don't know about a manual mode switch. Was your car a converted auto or always a manual? If it was a converted auto there is a bit in the DIY section on manual conversions which tells you which fuses/terminals under the battery you have to short out to allow the engine to assume that the g/box is in neutral so it can start.
A quick search suggests your pic is of the auto g/box ecu
as far as i knew, auto ecus work fine but you need to trick the "park switch" and some other switch into beleive its always in gear.
Like so
The plug at the top has been looped to complete the inhibitor switch circuit so the car believes it is in Park
I've never worked on an C34 but I'd say under the centre console. It looks like a logic control unit so it'll be looking for the position between the gear selector and then opening the circuit to the steering and stick shift switches and sending that back onto to the tranny control unit. They're often hidden in and around the centre consoles on other cars. I'd say given the simplicity of it's function, if it was all good then dead after install, you've probably accidentally loosened a connector.
  • 7 months later...
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
