Hi Guys,
Other past 3 months I have had the central column (radio and heating controls) flickering on and off on my V35.
A about a week ago it turned off for good. I took the car to a local auto electrician and was told that the central control module is shot and needs to be replaced. Apparently it quite common with a few cars these days. It my understanding this may include the radio and heading controls???
I am a little lost as to what to do next.
Why can I buy this part from?
Is it called "central control module"?
Any advice would be very much appreciated.
https://www.sau.com.au/forums/topic/460095-central-column-dropout/
Pretty common for the integrated stereo to take out the aircon. You need to source a dual din facia off a base model wreck, then you can find yourself a decent stereo.
There are aftermarket Metra kits available, but they are shitty compared to a stock dual din facia.
There is plenty of info in the V35 section above, and the Stagea one also.
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
