Hi ladies and gents.
I recently had my built 25/30 tuned, now anything over 20 psi my intercooler just ran out of efficiency and intake air temps raised dramatically. Currently I have a cheap ebay cooler, what brand intercooler have people had success with? Having a look on forums intercoolers seem to be a non existing topic. Any advice would be great, Cheers!
https://www.sau.com.au/forums/topic/460139-intercooler-options/
Whats your price range? If your willing to go up to the 800-1000 mark you can get a good pwr core or if thats out of your price range there is a cheap chinese brand takashi which is one of the better cheap coolers and work well for there price <$200.
You could put a massive intercooler on, but it won't help cool superheated air. Sounds to me like your turbo is too small, what are you running? Where is your temp gauge, and do you have one pre and post cooler?
Yeah I reckon the pwr would be a bit out of my price range being in tassie it doesn't exactly get that hot ha.
It already has a 600×300 cooler so I wouldn't think bigger or thicker would help much. Turbo is relatively small being a kinugawa t67 with a t04z compressor housing and 10cm rear turbine. Engine temp seems to be fine and sits around the 80° mark under load. I only have one temp sensor on the cold side of cooler piping.
I had a cooling pro front mount kit previously on my car and it pretty much dropped out after 265kw at 18 psi... in my experience not worth looking at.. your better off spending a bit more money to get some quailty gear..im running a entry level plazmaman and its been outstanding so far. Best of luck
I had a cooler pro on my R34 and I managed 320rwkw but my tuner said that was its limit, temps were starting to creep up above that so probably not worth looking at for you. If you want to do some reading jump on the Hypergear thread and search for all the results that Stao posted when he went through a heap of intercoolers for testing.
I think from memory he found that the PWR was best and also one of the standard GTR coolers was really good but I can't remember what model it was from. It'll be on there somewhere. I'd really suggest having a read of that
Ok cheers for the input guys, cooling pro seems to be a no go. I have heard good results about the base model plazmaman so that sounds the go. Il have a quick geez through the hypergear thread. I was at 345kw at which the cooler dropped it's efficiency.
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
