Hey guys, I've started a group buy for some tinted headlights and taillights for V35 and V36 coupes and sedans. Just gauging interest at this point in time so if you might possibly be interested please have a read of the linked group buy.
V35/ V36 Tinted Headlights/ Taillights Group Buy.
Cheers, Brenton.
Tinting taillights is legal yes. I believe your brake lights just need to still be visable from a certain distance away so providing they're not too dark they would be fine. I can not however confirm or deny whether the 20% or 35% are legal. As for having more cop attention, someone on the fb group I also posted this to said he's been running tinted taillights for over 3 years and has never had an issue with cops. Don't drive like a dick and you would be fine I would imagine. :P
What about the night reflectors that are built into the tail lights and just dont work once tint is applied on the lights?
One of my work mates was running just a bit lowered (not slammed) SS ute for a number of years until got pulled over by an unhappy cop. Caused him a bit of drama going through pits two times. It appeared that he needed to put not only original springs but also replace all shockies cause they were 5mm lower (sagged due to time) plus his exhaust system was modified all over. Also needed to fix all leaks which holdens are notorious for.
Edited by MDCAT
Never even thought of that as this is the first car I've had with built in reflectors. :P Not too sure on the legality of that.
Sounds to me like we have different definitions of "a bit lowered".
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
