Front has Cusco Adjustable top arms, 4 different settings... it's currently set to max negitive which should be about -2.5 deg, can get -3 to -3.5 I think if you also get an accentric bolt / bushes up there.
Flip the plate on the arm and you'll get a bit more.
Max the castor untill you hit the gaurd, then back it off.
+2mm total on the front toe
Neg 1.2 on the rear
-1 total on the rear toe
  • Like 2
Yep
Pretty sure you just rock up and call the guy and they'll unlock a garage. I'll try and sort it out beforehand though. If you PM me your phone number and bring some cash on the day I'll make sure to keep a space for you.
Probably also handy for any repairs that can be done with hand tools - couple of us will be bringing our tools.
Ok guys,
Who will be there on Sunday so I can make sure we bring enough steaks! Also SAU will have a garage for people to chill out in / get out of the weather.
Matt Lowth
Potato
Simone
13 Crag
Wog
Alex
Gav
Aaron
Birds +1
Darren
Borci88
Phantc_15
srs14t
Crzy32
Anyone Else?
    • Goddam! Thats the dream, neo heads seem hard to come by these days though, best I've seen is $2-3k or there's a full motor for $7k atm
    • Cheers for the input, 450kw on poncams is impressive! I assumed you'd need 264 or 272 for that power level, good to know you don't need to rev that high to hit it, just don't want to buy the cams etc then find out the hydraulic lifters suck haha The box will be getting reconditioned too, possibly an aftermarket gearset if it turns out they're toast, cheers I'll keep that in mind
    • I think definitely get a manual oil pressure gauge on it then. Double check if it's really dropping pressure that low.
    • yes sorry i should of spoke better, all sensors are grounded into their specific homes in the ecu, the ecu is then grounded to the chassis itself along with the EFI relay.
    • I'll check the wiring plan tomorrow. Now when you say ALL the earth's are to the chassis, is that including the sensor ground from the ECU? Certain items should not be grounded to the car/body/chassis, they should ground back to specific ground pins on the ECU.
