Anybody have any idea if this is normal? Went for a drive in this 36c weather and the car was idling at 16afr. Doesn't seem right. I can hear the fuel pump screaming its nut off in the tank. It is much less than a year old. The noise doesn't fuss me but i believe the noise is a side effect from the heat and its performing poorly as the fuel must be hot.
Any suggestions? The last thing i want is the pump failing or not giving enough fuel to the car this summer. It was fine the last time i drove pre bs weather. Its a walbro 255l drop in.
https://www.sau.com.au/forums/topic/460158-walbro-fuel-pump-screaming/
Was it noisey from the moment the car started or did it develop during the drive?
If it was noisey since it started, I wouldnt suspect heat. Unless you have a fuel cooler, it will probably get about as warm as it was on startup just cycling through the system.
A genuine Walbro 255 shouldn't scream, unless it's under massive stress, such as 80+psi fuel pressure, or high temps as you mentioned.
Have you got under the car and felt the fuel tank? It was 40 odd degrees yesterday wasn't it?
It developed to the point I could hear it while cruising. Electronics generally do not like heat, they don't perform as efficiently. Does this still apply with the pump?
Its genuine, I bought it off you. Its heat related. The car will not do it when it starts but builds up to it. Tomorrow should be about 15c cooler than today so will test and see what happens. Noise I can live with but the afr's changing so drastically(from 13.8 idle to 16.7) isn't good. Seems only to affect idle though.
Would beefing up the wiring further help?
I've done the grounding mod. The pump never has an issue. Voltage is stable in the vehicle. I've beefed up the grounding wire and I think I also beefed up the wiring in the tank but yeah essentially just grounded the pump control module.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
