Eh.. I have a gfb response.. once the factory one started krooing and not holding boost i knew it was a goneburger..
Good thing is you can adjust it to full recirc, or full vent, or anywhere in between.
I have it full recirc with a bit of choo choo choo under light depress but the shudder is almost non existent.
It has a spring tension bolt at the top which can be wound in or wound out or you can purchase a softer spring.
When its 75% recirc and 25% vent it sounds nice with a PoPshhh.. some like some dont lol..
I don't mind the sound, I just hate the fact it dumps precious fuel down the exhaust every time it TuTu's.
ok so looking at the softer spring option since I already bought the plumb back.
Turbosmart website not very comprehensive on information.
So stock spring is : -19 InHg high vac and -9 InHg low vac
soft spring is : -13 InHg high vac and -3 InHg low vac
Will the soft spring hold a solid 18-19 psi with a high flow on the VQ25DET and will it fix the shudder or just reduce it ?
You need to understand how a BOV works, there is equal pressure on both sides of the piston under boost, so theoretically any spring should hold boost without opening.
If you don't want the shudder, put the stock BOV back on, or tune the car to get rid of the hesitation. Any modification from stock will take the ecu out of it's normal operating conditions and ruin the drivability to some extent, you usually go backwards unless the engine is tuned to compensate, especially with boost.
  • Like 1
Exactly; technically the spring really only needs to return the piston to it's seat after a pressure relief event.
The spring in the OEM BOV is very light.
Would it be possible to drill a pilot hole/bypass port (only 2-3mm dia) in the piston of the turbosmart to allow an amount of bypass air like a stock BOV?
This might give the benefit of a better sealing BOV, without the issues with transient spiking.
The stock BOV plastic disc is floating on the shaft and starts to leak with age. I replaced mine with a GTR item from my old 33R which doesn't use the bleed hole and has a larger discharge area and metal disc over plastic. Spool up improved. No shudder.
Edited by BoostdR
  • Like 1
  • 1 month later...
33GTR BOV. Softer spring. No stutter, seems to hold boost ok. Much bigger discharge port. MAFLESS tune
http://www.youtube.com/watch?v=kM79IziIY2U
I'll do some logging on the way to work to check boost levels.
Hmm okay, have put in the soft spring in the Turbosmart Plumb back, still have shudder but not as violent.
Haven't tested it on freeway driving yet which is the worst, but still expect a bit.
Anyone tried the Greddy floating valve type- dual spring ?
Also huge price difference in the Turbosmart dual port and Greddy FV style.
I know stock BOV or lowering the boost will sort it out, but I want to run high boost if I can.
yep checked it, no restrictor.
I'm blown away how smooth and comfortable the M35 is to drive.
The shudder really spoils this for me.
Maybe the re-circ port is too close to the AFM ?
Or do you think the shudder is reversion through the turbo ?
Yes the size of the vacuum line helps. Smaller id and it will add to the cause of the shudder. The reason why they went away from the dual vent system or push pull was because of the leak in the diaphragm which end up leaning your engine to the point of detonation and stalling. Especially in the cheap copies that popped up.
Edited by Reaperblitz
You'd think the resonator would improve it, that's it's purpose to absorb pulses.
Anyway,
Changing the intake with an AMPerformance soon.
Hoping it will better.
Might give the floating valve type BOV a go.
I suspect the shudder is caused by the BOV valve bouncing up and down on the spring.
Did you notice instant shudder after putting in the grub screw on the stock BOV ?
Is it just the extra 2 psi causing this.. Doubt it.
The stocker must open much more easily then, than the Turbosmart...
Have a look at the Greddy FV valves ( floating valves)
They are supposed to open much quicker than single spring.
The only thing is the 40mm outlet, having trouble finding a 40-30 reducer
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
