Eh.. I have a gfb response.. once the factory one started krooing and not holding boost i knew it was a goneburger..
Good thing is you can adjust it to full recirc, or full vent, or anywhere in between.
I have it full recirc with a bit of choo choo choo under light depress but the shudder is almost non existent.
It has a spring tension bolt at the top which can be wound in or wound out or you can purchase a softer spring.
When its 75% recirc and 25% vent it sounds nice with a PoPshhh.. some like some dont lol..
I don't mind the sound, I just hate the fact it dumps precious fuel down the exhaust every time it TuTu's.
ok so looking at the softer spring option since I already bought the plumb back.
Turbosmart website not very comprehensive on information.
So stock spring is : -19 InHg high vac and -9 InHg low vac
soft spring is : -13 InHg high vac and -3 InHg low vac
Will the soft spring hold a solid 18-19 psi with a high flow on the VQ25DET and will it fix the shudder or just reduce it ?
You need to understand how a BOV works, there is equal pressure on both sides of the piston under boost, so theoretically any spring should hold boost without opening.
If you don't want the shudder, put the stock BOV back on, or tune the car to get rid of the hesitation. Any modification from stock will take the ecu out of it's normal operating conditions and ruin the drivability to some extent, you usually go backwards unless the engine is tuned to compensate, especially with boost.
  • Like 1
Exactly; technically the spring really only needs to return the piston to it's seat after a pressure relief event.
The spring in the OEM BOV is very light.
Would it be possible to drill a pilot hole/bypass port (only 2-3mm dia) in the piston of the turbosmart to allow an amount of bypass air like a stock BOV?
This might give the benefit of a better sealing BOV, without the issues with transient spiking.
The stock BOV plastic disc is floating on the shaft and starts to leak with age. I replaced mine with a GTR item from my old 33R which doesn't use the bleed hole and has a larger discharge area and metal disc over plastic. Spool up improved. No shudder.
Edited by BoostdR
  • Like 1
  • 1 month later...
33GTR BOV. Softer spring. No stutter, seems to hold boost ok. Much bigger discharge port. MAFLESS tune
http://www.youtube.com/watch?v=kM79IziIY2U
I'll do some logging on the way to work to check boost levels.
Hmm okay, have put in the soft spring in the Turbosmart Plumb back, still have shudder but not as violent.
Haven't tested it on freeway driving yet which is the worst, but still expect a bit.
Anyone tried the Greddy floating valve type- dual spring ?
Also huge price difference in the Turbosmart dual port and Greddy FV style.
I know stock BOV or lowering the boost will sort it out, but I want to run high boost if I can.
yep checked it, no restrictor.
I'm blown away how smooth and comfortable the M35 is to drive.
The shudder really spoils this for me.
Maybe the re-circ port is too close to the AFM ?
Or do you think the shudder is reversion through the turbo ?
Yes the size of the vacuum line helps. Smaller id and it will add to the cause of the shudder. The reason why they went away from the dual vent system or push pull was because of the leak in the diaphragm which end up leaning your engine to the point of detonation and stalling. Especially in the cheap copies that popped up.
Edited by Reaperblitz
You'd think the resonator would improve it, that's it's purpose to absorb pulses.
Anyway,
Changing the intake with an AMPerformance soon.
Hoping it will better.
Might give the floating valve type BOV a go.
I suspect the shudder is caused by the BOV valve bouncing up and down on the spring.
Did you notice instant shudder after putting in the grub screw on the stock BOV ?
Is it just the extra 2 psi causing this.. Doubt it.
The stocker must open much more easily then, than the Turbosmart...
Have a look at the Greddy FV valves ( floating valves)
They are supposed to open much quicker than single spring.
The only thing is the 40mm outlet, having trouble finding a 40-30 reducer
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
