Is it just me or has this thread gone full circle a few times?
The best way to avoid shutter from an aftermarket bov is to tune to match or keep the stock one and avoid the shutter, is that pretty much where we have landed on this?
  • Like 2
I think that is the general consensus. Taking steps to ensure you don't have boost or vacuum leaks and checking for restrictìon pill or using proper hose that doesn't "suck in" may help but in the end it's use stock, a good adjustable one or get a tune ?
Edited by Reaperblitz
nah. but. what about 'insert something irrelevant'
Yer, well my Turbosmart Kompact still shudders with the soft spring and I'm pretty sure it's opening on boost too.
Seem to have varying spool / boost levels
There was better spool with the standard spring.
The shudder is on pigeon sound, which means the BOV ain't releasing enough at low boost
The FV series valves are supposed to open more on vacuum than single spring types.
Worth trying , especially if it reduces strain on the shaft, and stops me spilling my coffee.
These are selling for over $400 from some sellers.
Scored one for $145
Just waiting on a 29mm recirc adapter from Nengun.
The trumpets unscrew and the adapters fit all three models.
See the fake has silver retainer ring on the base.
I also noticed the Greddy sticker is shit on the fake too.
The spring is way harder to push in and you can hear it grind when it travels.
I sent pics to Greddy, they confirmed it was a fake.
Looking inside the genuine one, the difference in quality is huge.
See how it goes.
Edited by conan7772
Scored one for $145
See how it goes.
either fit stock back or tune the car, otherwise you will always get pigeon sound whatever you use which brand BOV/soft spring
also if you can develop some electric solenoid valve controlled BOV like modern VW/Audi/BMW/Benz, you can also get rid of the pigeon sound
Edited by YangLIU
My suggestion, block the kent off and see what the response is like. It is a good way to see what the boost is actually doing too. Do you have a good boost gauge? The only time I have seen shuddering is when the car is running over 20psi untuned.
Mutt,
The Nissan adapter faces the return either up or down.
Meaning I'll need an elbow off the bov, down hits the engine, up bonnet won't close.
Haven't dry fitted yet but it doesn't look good.
I'll have to make my own adapter I think like this one.
Edited by conan7772
I just fitted a stock M35 BOV into a 33gtst, bolts straight in, so I have no idea what's going on there...
The only car I have seen where I couldn't get rid of the juddering was actually running 21psi due to having a 1 bar actuator and still running the stock bleed circuit. What boost does it run on a big uphill stomp? If it's too much that will be your answer. the stock ecu is in protection mode and dumping fuel.
It mostly shudders when I back off at 3-5 psi
Here's the adapter I have.
It puts the vent up or down, not to the side where it needs to be.
Nengun sell one for the RB25DET with all the holes in line.
Edited by conan7772
Yeah that is defiantly the wrong adapter plat you just need one where all the blots holes are in a strait line. Best look at your bov and where the bolt holes are and do some research into a suitable adapter
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
