I have 5 NEW MSI KT4V Motherboards.
Product Specs CPU • Supports Socket A (Socket 462) for AMD® Athlon™ XP/ Athlon™/Duron™ processor • Supports 800MHz up to Athlon™ XP 2800+ processor
Chipset VIA® KT400 Chipset - FSB @200/266/333 MHz - Supports DDR200/266/333/400 memory - AGP 8X and PCI advanced high performance memory controller. VIA® VT8235 Chipset - Integrated Direct Sound AC'97 audio - Dual channel Ultra DMA 33/66/100/133 master mode EIDE controller - ACPI & PC2001 compliant enhanced power management - Integrated USB 2.0 controller
FSB 100/133/166(200/266/333)MHz clocks are supported.
Main Memory • Supports six memory banks using three 184-pin DDR SDRAMs. • Supports up to 3GB memory size. • Supports DDR400*/DDR333/DDR266/DDR200 SDRAM • No support ECC Function
Slots • One AGP (Accelerated Graphics Port) 1.5V 8x/4x slot • Six 32-bit PCI bus slots (support 3.3v/5v PCI bus interface) • One CNR (Communication Network Riser) slot
On-Board IDE • An IDE controller on the VT8235 chipset provides IDE HDD/ CD-ROM with PIO, Bus Master and Ultra DMA133/100/66/33 operation modes • Can connect up to four IDE devices
Audio RealTek ALC650 6-channel audio
Lan (Optional) VIA VT6103 LAN controller
On-Board Peripherals On-Board Peripherals include: - 1 floppy port supports 2 FDDs with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes - 2 serial ports (COM A + COM B) - 1 parallel port supports SPP/EPP/ECP mode - Vertical audio ports - 1 SPDIF output (1 x 3) with housing (Optional) - 6 USB ports (Rear x 4/ Front x 2)
BIOS • The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically. • The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
Dimension 30.5 cm(L) x 21 cm(W) ATX Form Factor
Mounting 6 mounting holes.
RRP: approx $90
Yours for $50
Please PM me if your interested
https://www.sau.com.au/forums/topic/46017-5-new-msi-motherboards-for-amd/
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
