5 New MSI Motherboards for AMD
Nizman
 Share
I have 5 NEW MSI KT4V Motherboards.
Product Specs CPU • Supports Socket A (Socket 462) for AMD® Athlon™ XP/ Athlon™/Duron™ processor • Supports 800MHz up to Athlon™ XP 2800+ processor
Chipset VIA® KT400 Chipset - FSB @200/266/333 MHz - Supports DDR200/266/333/400 memory - AGP 8X and PCI advanced high performance memory controller. VIA® VT8235 Chipset - Integrated Direct Sound AC'97 audio - Dual channel Ultra DMA 33/66/100/133 master mode EIDE controller - ACPI & PC2001 compliant enhanced power management - Integrated USB 2.0 controller
FSB 100/133/166(200/266/333)MHz clocks are supported.
Main Memory • Supports six memory banks using three 184-pin DDR SDRAMs. • Supports up to 3GB memory size. • Supports DDR400*/DDR333/DDR266/DDR200 SDRAM • No support ECC Function
Slots • One AGP (Accelerated Graphics Port) 1.5V 8x/4x slot • Six 32-bit PCI bus slots (support 3.3v/5v PCI bus interface) • One CNR (Communication Network Riser) slot
On-Board IDE • An IDE controller on the VT8235 chipset provides IDE HDD/ CD-ROM with PIO, Bus Master and Ultra DMA133/100/66/33 operation modes • Can connect up to four IDE devices
Audio RealTek ALC650 6-channel audio
Lan (Optional) VIA VT6103 LAN controller
On-Board Peripherals On-Board Peripherals include: - 1 floppy port supports 2 FDDs with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes - 2 serial ports (COM A + COM B) - 1 parallel port supports SPP/EPP/ECP mode - Vertical audio ports - 1 SPDIF output (1 x 3) with housing (Optional) - 6 USB ports (Rear x 4/ Front x 2)
BIOS • The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically. • The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
Dimension 30.5 cm(L) x 21 cm(W) ATX Form Factor
Mounting 6 mounting holes.
RRP: approx $90
Yours for $50
Please PM me if your interested
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
