I have looked around on the forums for a bit now and hadn't found any clear answers so tried it out myself and wanted to let everyone know that this works.
If you are looking for a cabin air filter for you wgnc34 series 2 I found that the filter from the Nissan Pathfinder R50 or Infiniti QX4 works. Below is a installation guide and comparison of filters
Open your glove box, squeeze the sides in to get it around the edges, disconnect the little white plastic clip at the back attacked to a string.
There are 4 screws on top and two on either side of them glove box
Remove the glove box from vehicle
Remove little metal clip on the bottom and pull filters out.
Here are 3 Side by side comparisons of old filter and pathfinder filter. As you can see they are the same size, except slightly thinner
Fits in and seals perfectly
For those in Canada you can pick this filter up from your local Canadian tire. Please post in the reply what the part numbers are for your country (FRAM FILTER CF10555)
I'm sure this is the same for R34 skylines as well
  • Like 2
https://www.sau.com.au/forums/topic/460184-cabin-air-filter-wgn34/
  • 2 years later...
For us in Australia, it can be bought from Supercheap Auto and any other store that stocks Ryco filters. Not sure how many will have it in stock in store... Supercheap don't seem to have them normally, but they can order it in.
Ryco RCA318P
Nissan OEM part number: AY685NS003
(Found - as it is the same as the R50 Pathfinder as mentioned above, just a little thinner.)
http://www.rycofilters.com.au/cat/product.html?stock=RCA318P#!/details
Edited by jamesnorman93
Not on shelf
  • 1 month later...
  • 2 years later...
  • 7 months later...
Bumping this because it is national you-might-be-running-aircon-through-disgusting-filters awareness day.
Did this the other day in my Series 2 Stagea. I was sufficiently disgusted. I presume the filters were changed some time in Japan going by the stickers in the glovebox, but I don't think they have seen any attention since. It's super easy to swap so really no excuse there. The Ryco RCA318P filters that James mentioned seem fine.
My lesson learned: try out the fan before screwing everything back in. I had old leaves and shit in the compartment when I took out the old filters. Brushed it it out but didn't vacuum. Put it back together with the new filters, turned on the fan and was blessed with a generous sprinkling of dusty debris. I presume vacuuming may have avoided it. Maybe.
This guide has great photos and steps to follow:
https://www.driveanotherday.com/stagea-cabin-filter/
Archive link for future generations: https://web.archive.org/web/20220105205535/https://www.driveanotherday.com/stagea-cabin-filter/
Attached is a comparison of the old and new filters. Though photos don't quite do it justice. There is this human instinct to get closer and smell things that look wrong. These looked bad enough that I didn't.
  • Thanks 1
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
